where is this suppose to be?, what is it anyway (pic) |
opera guy |
Jul 10 2004, 02:34 AM
Member Group: Members Posts: 337 Joined: 28-June 04 From: upland, ca Member No.: 2,268 |
ok, right by the battery in my 73 2.0 there is this thing (see pics) just lying there. it looks like it's suppose to be bolted somewhere.
can someone please tell me what it does, and where it suppose to be bolted? be great if you have a pic of this thing bolted to its proper place. for now, its just loose, not bolted on anything. Attached image(s) |
opera guy |
pic 2
Martin Baker |
Jul 10 2004, 04:28 AM
I just heard I sold my cars! Group: Members Posts: 1,140 Joined: 11-February 03 Member No.: 290 Region Association: Northern California |
Manifold Pressure Sensor. It should be on a mounting bracket, attached to the right side of the engine compartment, just below where it's lying now. Not really a great thing for it to just be flying around loose in the engine compartment, as it's one of the most important componets of your fuel inj. system.
Joe Ricard |
Jul 10 2004, 04:53 AM
I would also get some clamps put on the fuel lines. Is that the fuel pressure regulator next to the MPS? there is a pedestal o the other side of the engine that it attaches to with a big nut on the threaded end.
Martin Baker |
Jul 10 2004, 05:01 AM
That's the decel valve, it would have mounted in the same place under the forward most bolt, for the MPS.
ChrisFoley |
Jul 10 2004, 05:19 AM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
You can just see the edge of the mounting location in the picture. It's the sheet metal piece welded onto the suspension console. The metal bracket (painted black)that attaches it has three slots where rubber grommets with brass inserts go that the screws go through. The bracket is hard mounted to the MPS and grommet mounted to the chassis almost exactly where the unit is now.
Jul 10 2004, 02:17 PM
QUOTE(Joe Ricard @ Jul 10 2004, 03:53 AM) I would also get some clamps put on the fuel lines. and while you're in there, replace those crappy clamps with the right kind of fuel-injection clamps ... (IMG:style_emoticons/default/wink.gif) Andy |
Lo-Fi Version | Time is now: 15th May 2024 - 04:49 AM |
