F/S-->914 Fuse Box & Fuse Box Cover, New Reproduction, F/S 914 Fuse Box & Fuse Box Cover, New Reproduction |
914sales |
Aug 23 2011, 03:19 PM
I'm new here ... Group: Members Posts: 0 Joined: 23-August 11 From: los angeles Member No.: 13,485 Region Association: None |
This is finally reproduced only by 356Devotion, using laser CAD computers to get the exact tabs snug fit in the fuse box and with all the correct symbols for your fuses. No need to buy a aftermarket regular numbered fuse box, this is exact copy of the original fuse box cover. $29.99 each, click on the link below for more info.
http://www.356devotion.com/356D-91461231610.html Also the 914 12 Pole Fuse Box http://www.356devotion.com/356D-91461231510.html This is a great reproduction made with a computer cad design, with exact specs of the original Porsche 12 pole fuse box. If your fuse box is rusted, cracked, time to replace it before getting a short. This fits snug into the metal frame with the screw holes aligning up correctly ready to be installed. Attached image(s) |
BuddyV |
Aug 23 2011, 04:05 PM
Robert Group: Members Posts: 555 Joined: 8-April 05 From: Santa Rosa, CA Member No.: 3,898 Region Association: Northern California |
Isn't the idea to use modern-style fuses if updating?
Really - I'm asking because I bought the alternative product with newer fuses, but have not installed it. Is one a benefit over the other? (I thought it was clear). Cheers. |
914sales |
Aug 23 2011, 04:09 PM
Isn't the idea to use modern-style fuses if updating? Really - I'm asking because I bought the alternative product with newer fuses, but have not installed it. Is one a benefit over the other? (I thought it was clear). Cheers. HI this fuse box is like the original it uses the ceramic style fuses, I've just taken the back and front of the fuse box picture, but this is just like the original box that's on the metal plate. Hope this helps |
biosurfer1 |
Aug 23 2011, 04:57 PM
Teener fo Life! Group: Members Posts: 3,020 Joined: 3-August 03 From: Roseville, CA Member No.: 977 Region Association: Northern California |
Not to the CW and originality gurus around here...personally I'm all for updating or modernizing things on my 914 but there is a big following who doesn't. Nice to have options for sure
Isn't the idea to use modern-style fuses if updating? Really - I'm asking because I bought the alternative product with newer fuses, but have not installed it. Is one a benefit over the other? (I thought it was clear). Cheers. |
BuddyV |
Aug 23 2011, 07:32 PM
I get it... thank you for clarifying.
Great to have options. Cheers! |
Lo-Fi Version | Time is now: 28th May 2024 - 01:48 AM |
