V8 Guys, Do I need these?, Cleaning out the engine bay |
pete |
Aug 24 2011, 09:29 AM
Member Group: Members Posts: 158 Joined: 23-August 10 From: New Jersey Member No.: 12,092 Region Association: North East States |
Hey, I disassembled it 10 years ago and am just now starting to work on it. I can't remember what was attached to the circled items. I was wondering if I need any of them for my SBC V8 conversion. Can any of these brackets/bolts/tubes be re-purposed for a V8? (IMG:style_emoticons/default/sawzall-smiley.gif) Taking it to anything I don't need.
pt_700 |
Aug 24 2011, 09:32 AM
Senior Member Group: Members Posts: 1,092 Joined: 4-March 10 From: san jose, ca Member No.: 11,430 Region Association: Northern California |
not that i would know but, i can't see any circled items in the pic you posted...
i too am planning a sbc conversion but, haven't yet begun the dis-assembly, still driving it! |
pete |
Aug 24 2011, 09:37 AM
ok, the circles didn't show. Try again.
pete |
Aug 24 2011, 09:38 AM
pete |
Aug 24 2011, 09:46 AM
ok, the circles didn't show. Try again. WTF? I pull up the file elsewhere and the black circles show. Weird. Attached image(s) |
pete |
Andyrew |
Aug 24 2011, 10:04 AM
The heater tube can be used for SOMETHING later down the road. I'd just cap it off (I used duct tape..)
The heater cable can be used for a choke or for something similar, I would leave the tube there and pull the cable till you need it. The rest is obsolete. |
stewteral |
Aug 24 2011, 10:09 AM
Old Member Group: Members Posts: 384 Joined: 4-December 07 From: Camarillo, CA Member No.: 8,424 Region Association: Southern California |
Hey, I disassembled it 10 years ago and am just now starting to work on it. I can't remember what was attached to the circled items. I was wondering if I need any of them for my SBC V8 conversion. Can any of these brackets/bolts/tubes be re-purposed for a V8? (IMG:style_emoticons/default/sawzall-smiley.gif) Taking it to anything I don't need. Hi Pete, From what I can see, I'd suggest replacing all the missing sheet metal in the hell hole for structural integrity, but leave the battery mount OFF. The space will allow work-around room with the Chevy installed. I'd suggest mounting the Batt. in the right corner of the rear trunk for these benefits: balancing weight, short power cable to starter and being away for batt killing heat! All the rest of the stock bit are needed. I mounted my 2-1/2" sq tube engine crossbar in the standard position after welding strengthening pcs to the stock mounts. Given how flimsy the inner mounting tabs for the swing arms are, it is advisable to brace them. My right side tab fractured from the added loading and after repair, I braced them with rod-ends threaded into sections of tubing. I hope the attached pics will help in visualizing how it all fits. Best of luck, Terry |
pete |
The heater tube can be used for SOMETHING later down the road. I'd just cap it off (I used duct tape..) The heater cable can be used for a choke or for something similar, I would leave the tube there and pull the cable till you need it. The rest is obsolete. So the bracket on the engine mount and the bracket on the control arm ear as well as the bracket on the wheel well (the other wheel well has the same bracket/screws) I can cut off? Has anyone run the radiator hoses down the heater tubes rather then under the car? |
pete |
Aug 24 2011, 10:15 AM
Hey, I disassembled it 10 years ago and am just now starting to work on it. I can't remember what was attached to the circled items. I was wondering if I need any of them for my SBC V8 conversion. Can any of these brackets/bolts/tubes be re-purposed for a V8? (IMG:style_emoticons/default/sawzall-smiley.gif) Taking it to anything I don't need. Hi Pete, From what I can see, I'd suggest replacing all the missing sheet metal in the hell hole for structural integrity, but leave the battery mount OFF. The space will allow work-around room with the Chevy installed. I'd suggest mounting the Batt. in the right corner of the rear trunk for these benefits: balancing weight, short power cable to starter and being away for batt killing heat! All the rest of the stock bit are needed. I mounted my 2-1/2" sq tube engine crossbar in the standard position after welding strengthening pcs to the stock mounts. Given how flimsy the inner mounting tabs for the swing arms are, it is advisable to brace them. My right side tab fractured from the added loading and after repair, I braced them with rod-ends threaded into sections of tubing. I hope the attached pics will help in visualizing how it all fits. Best of luck, Terry Hi Terry, yes, I look forward to adding some round tube reinforcements. Right now I'm cutting out everything I don't need to make room for paint stripping, and hell hole rust repair as well as just removing things I don't need so I don't have to clean them LOL. |
pete |
Aug 24 2011, 10:25 AM
Hey, I disassembled it 10 years ago and am just now starting to work on it. I can't remember what was attached to the circled items. I was wondering if I need any of them for my SBC V8 conversion. Can any of these brackets/bolts/tubes be re-purposed for a V8? (IMG:style_emoticons/default/sawzall-smiley.gif) Taking it to anything I don't need. Hi Pete, From what I can see, I'd suggest replacing all the missing sheet metal in the hell hole for structural integrity, but leave the battery mount OFF. The space will allow work-around room with the Chevy installed. I'd suggest mounting the Batt. in the right corner of the rear trunk for these benefits: balancing weight, short power cable to starter and being away for batt killing heat! All the rest of the stock bit are needed. I mounted my 2-1/2" sq tube engine crossbar in the standard position after welding strengthening pcs to the stock mounts. Given how flimsy the inner mounting tabs for the swing arms are, it is advisable to brace them. My right side tab fractured from the added loading and after repair, I braced them with rod-ends threaded into sections of tubing. I hope the attached pics will help in visualizing how it all fits. Best of luck, Terry Hi Terry, yes, I look forward to adding some round tube reinforcements. Right now I'm cutting out everything I don't need to make room for paint stripping, and hell hole rust repair as well as just removing things I don't need so I don't have to clean them LOL. Your exhaust system is awesome by the way! |
pete |
Aug 24 2011, 10:45 AM
Terry, did you rivet your flares on? I decided on Dzus fasteners for easy removal. Went a little crazy on the rear flares. I haven't riveted the fasteners in place yet, I don't think I will paint them.
Ductech |
Member Group: Members Posts: 356 Joined: 16-July 10 From: AridZona Member No.: 11,949 Region Association: Southwest Region |
there is a subie convert by the name of britian if my memory serves me well. He ran hosing down the original hot air transfer tunnels. Looks to be clean yet pain in the ass way of doing it. and good god how much 914 is left after a v8 conversion? that car looks like its a motor with a 914 front end thrown on it.
pete |
Aug 24 2011, 10:46 AM
Terry, did you rivet your flares on? I decided on Dzus fasteners for easy removal. Went a little crazy on the rear flares. I haven't riveted the fasteners in place yet, I don't think I will paint them. Attached image(s) |
Andyrew |
Aug 24 2011, 11:21 AM
The heater tube can be used for SOMETHING later down the road. I'd just cap it off (I used duct tape..) The heater cable can be used for a choke or for something similar, I would leave the tube there and pull the cable till you need it. The rest is obsolete. So the bracket on the engine mount and the bracket on the control arm ear as well as the bracket on the wheel well (the other wheel well has the same bracket/screws) I can cut off? Has anyone run the radiator hoses down the heater tubes rather then under the car? The brackets on the right and left are for the trunk torsion bars. Your going to run trunk shocks right? (I HIGHLY suggest it...) And yes you can run your lines through the heater tubes, unfortunately you have to either run the hose inside the cabin (read a hot cabin) or in the fenderwell (read tire clearance). Brittan did it in his yellow subi conversion on JP's old car. Multiple others have as well. But it DOES create heat in the cabin. My lines under the car have never hit anything and doesnt create heat in the cabin. |
stewteral |
Aug 24 2011, 01:17 PM
ok, the circles didn't show. Try again. WTF? I pull up the file elsewhere and the black circles show. Weird. Hey Pete, Now I see the bits you were talking about removing. I have needed NONE of them except the heater tube through which I ran my Aeroquip fuel line (back from the tank). Sawzall Away!! Terry |
stewteral |
Aug 24 2011, 01:32 PM
The heater tube can be used for SOMETHING later down the road. I'd just cap it off (I used duct tape..) The heater cable can be used for a choke or for something similar, I would leave the tube there and pull the cable till you need it. The rest is obsolete. So the bracket on the engine mount and the bracket on the control arm ear as well as the bracket on the wheel well (the other wheel well has the same bracket/screws) I can cut off? Has anyone run the radiator hoses down the heater tubes rather then under the car? hey Pete, There is NOT a direct route from the front trunk to the heater tubes. As I said, I ran my fuel line down the right tube, but first it had to come into the passenger footwell and then to the heater tube. I ran my water tubes inside the central tunnel! I found that there is room at the front of the tunnel to run tubing UNDER the fuel tank and with a cutting a slotted hole, into the front trunk. I chose to sweat 1-1/4" copper tubing (no problems in 8 years now), but one could just run Gates green-stripe all the way from the radiator back to the engine via my routing. Whatever you do, Please don't run the tubes/hoses under the car as they are bound to get snagged! behind the rocker panels is another good option. I hope this helps, Terry |
stewteral |
Aug 24 2011, 01:50 PM
Terry, did you rivet your flares on? I decided on Dzus fasteners for easy removal. Went a little crazy on the rear flares. I haven't riveted the fasteners in place yet, I don't think I will paint them. Pete, YES. I used 3/8's pop rivets and then bondo'd in their center holes. Painted over, they look OK. As I want to drive my car on the street & track, I compromised instead of your Full-Racer approach. The Dzus approach certainly make swapping fender an easy process for a committed track car. All the same, I a tire let go and take off a rear flare 5 months ago and it wasn't too much of a chore replacing it. Best, Terry |
stewteral |
Aug 24 2011, 01:56 PM
there is a subie convert by the name of britian if my memory serves me well. He ran hosing down the original hot air transfer tunnels. Looks to be clean yet pain in the ass way of doing it. and good god how much 914 is left after a v8 conversion? that car looks like its a motor with a 914 front end thrown on it. Hey Ductech, I'm hoping you think it looks COOL, as I do! (IMG:style_emoticons/default/smile.gif) I just HAD to have the 180 degree Schoenfeld headers as it changes the tumpa-bumpa V8 exhaust note into a screaming banshee race engine whine!! The sound is VERY COOL! Terry |
ewdysar |
Aug 24 2011, 03:00 PM
What happens here, stays here. Group: Members Posts: 558 Joined: 29-October 04 From: Altadena, CA Member No.: 3,030 |
there is a subie convert by the name of britian if my memory serves me well. He ran hosing down the original hot air transfer tunnels. Looks to be clean yet pain in the ass way of doing it. and good god how much 914 is left after a v8 conversion? that car looks like its a motor with a 914 front end thrown on it. Terry's V8 conversion as one of the more extreme examples. Many V8 914s, like mine, have rear trunks that are complete with roof brackets, carpet and such, just a small 4" x 4" cutout at the middle of the front of the trunk for distributor clearance. The front trunk is the biggest sacrifice, with the radiator up there, ther's no room for a laydown spare. For the outside or the interior, there's no indication that my car has a V8, as long as it's parked. The funny thing is that I still focus on Porsche parts because I want to keep it "original". (IMG:style_emoticons/default/screwy.gif) A number of people have run the coolant hoses through the heater vents, up to the dash area, and back down to the radiator. Works well, but burping the lines of trapped air is problematic. Some people solved this with small bleed valves at the high points, but it's still a pain. Almost all V8 conversions run Gates (or similar) hose under the car with virtually no problems. My hoses have been good for 15 years. Flexible hose is preferred under the car, hardlines may get crimped or broken going over speed bumps, steep driveways or road debris. The rubber hoses seem to shrug that stuff off. |
Lo-Fi Version | Time is now: 15th May 2024 - 01:59 PM |
