Cranks now but no spark |
Ctrout |
Jul 10 2004, 04:59 PM
Member Group: Members Posts: 377 Joined: 20-May 04 From: Mountain Home, ID. Member No.: 2,091 |
I fixed the problem of the mess under the pass seat so the car cranks now. I even fixed it so that my seat belt warning light and oil pressure light work. I replaced all of the fuel hoses under the lid because I had a leak. Now I am ready to hear this thing run but I'm getting no spark. Is there a way to figure out if it is the coil without buying a new one? Where would be the best place to start troubleshooting?
ArtechnikA |
Jul 10 2004, 05:11 PM
i'd start at the points and work forward; ignition issues are almost always in the low-tension side.
this presumes you have the stock battery-condensor/coil ignition. if you have some kind of electronic stuff, the teachniques are the same but the specifics vary. are you -certain- you have no spark, as opposed to no injection ? |
Ctrout |
Jul 10 2004, 05:26 PM
I'm sure that I'm not getting spark because I pulled the coil wire and watched for spark while cranking, holding the coil wire close to agound. This doesn't mean that I'm getting injection though. I have fuel pressure. The ignition is bone-stock. I think the points may be corroded. I'll try cleaning them up and see if this helps.
Lo-Fi Version | Time is now: 4th June 2024 - 07:57 PM |
