Fuse positions left to right on a 74, please help :) |
Aaron Cox |
Jul 10 2004, 08:40 PM
knocked em all loose...and just got new fuses... dont know where what rating fuse goes... dont have a cover, so dont know which one is wha
please help (IMG:style_emoticons/default/wink.gif) |
Aaron Cox |
Jul 10 2004, 08:41 PM
got it thanks...
QUOTE 1974 Porsche 914 Fuse Index I made up a list of fuses and fuse-protected items on the fuse block and regulator plate recently from studying the factory manuals which some may find useful. Other year cars are different. -- Jeff Bowlsby S1 8 Amp Left headlamp, high beam High beam indicator lamp S2 8 Amp Right headlamp, high beam S3 8 Amp Left headlamp, low beam S4 8 Amp Right headlamp, low beam S5 8 Amp Left parking lamp Front side marker lamp Left stop/rear lamp Rear side marker lamp S6 8 Amp Right parking lamp Right stop/rear lamp Rear side marker lamp Front side marker lamp S7 8 Amp Clock illumination lamp Oil temperature illumination lamp Voltmeter illumination lamp Rear luggage/engine bay lamp Rear license plate lamps (2) Defroster lever illumination lamp S8 16 Amp Cigar lighter Heater control assembly illum. lamps (3) Fresh air blower indicator lamp Fresh air blower motor Windshield wiper motor S9 8 Amp Alternator charge indicator lamp Low fuel warning lamp Fuel gauge Oil pressure indicator lamp Tachometer Left/right rear stop lamps Left/right back-up lights Oil temperature gauge Voltmeter gauge Clock S10 16 Amp Parking lamps indicator lamp (on dash) Left/right fog lamps Horns S11 8 Amp Hazard flasher indicator lamp (dash) Turn signal indicator lamp (dash) Parking brake warning indicator lamp (dash) Left/right, front/rear turn signal lamps Speedometer illumination lamp (2) Fuel gauge illumination lamp Tachometer illumination lamp (2) Temperature control illumination lamp Interior cabin light (backpad) S12 16 Amp Left/right retractable headlight motors (2) Front fuse on voltage regulator plate is not used. S13 25 Amp (rear fuse on voltage regulator plate) Heater fan motor Fuel pump Rear window defroster Auxiliary air regulator Items not fused Fasten seatbelt lamp on dash Fuel injection ECU Starter motor Ignition switch Headlamp switch Fog lamp indicator lamp (dash) Seat belt warning buzze |
Lo-Fi Version | Time is now: 4th June 2024 - 08:43 AM |
