got it thanks...
1974 Porsche 914 Fuse Index
I made up a list of fuses and fuse-protected items on the fuse block and regulator plate recently from studying the factory manuals which some may find useful. Other year cars are different.
-- Jeff Bowlsby
S1 8 Amp
Left headlamp, high beam
High beam indicator lamp
S2 8 Amp
Right headlamp, high beam
S3 8 Amp
Left headlamp, low beam
S4 8 Amp
Right headlamp, low beam
S5 8 Amp
Left parking lamp
Front side marker lamp
Left stop/rear lamp
Rear side marker lamp
S6 8 Amp
Right parking lamp
Right stop/rear lamp
S7 8 Amp
Clock illumination lamp
Oil temperature illumination lamp
Voltmeter illumination lamp
Rear luggage/engine bay lamp
Rear license plate lamps (2)
Defroster lever illumination lamp
S8 16 Amp
Cigar lighter
Heater control assembly illum. lamps (3)
Fresh air blower indicator lamp
Fresh air blower motor
Windshield wiper motor
S9 8 Amp
Alternator charge indicator lamp
Low fuel warning lamp
Fuel gauge
Oil pressure indicator lamp
Tachometer
Left/right rear stop lamps
Left/right back-up lights
Oil temperature gauge
Voltmeter gauge
Clock
S10 16 Amp
Parking lamps indicator lamp (on dash)
Left/right fog lamps
Horns
S11 8 Amp
Hazard flasher indicator lamp (dash)
Turn signal indicator lamp (dash)
Parking brake warning indicator lamp (dash)
Left/right, front/rear turn signal lamps
Speedometer illumination lamp (2)
Fuel gauge illumination lamp
Tachometer illumination lamp (2)
Temperature control illumination lamp
Interior cabin light (backpad)
S12 16 Amp
Left/right retractable headlight motors (2)
Front fuse on voltage regulator plate is not used.
S13 25 Amp (rear fuse on voltage regulator plate)
Heater fan motor
Fuel pump
Rear window defroster
Auxiliary air regulator
Items not fused
Fasten seatbelt lamp on dash
Fuel injection ECU
Starter motor
Ignition switch
Headlamp switch
Fog lamp indicator lamp (dash)
Seat belt warning buzze
