Jim Kelly's V8 re-conversion |
scotty b |
Aug 29 2011, 07:12 PM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
Jim dropped his car off to have me re-do the V8 ( 307 ) install he and Rod did a few years ago. This time around it will be getting the complete Renegade treatment, a new set of Dr. Sheas handi work. Elephant poly bronze bushings, sway bars, 108 c.v.'s. Some BIG ass sway away axles, and a lot of cleaning / detailing. I got started last friday pulling the engine and trans at the last minute before leaving for Matts party. Dr. Evil was going to do a quilie rebuild prior to the party's start. Once we opened up the box, the truth became known. Unfortunaely Jim's intermediate plate was shot. One of the worst Mikes has seen, so Mike took the stack back home to install a good plate, and do the gear swapping. I got to the shop today to find most of the area was tornm to shreds from Irene, so without power or water I couldn't do much other than tear the engine most of the way down. No way to get the flywheel ff until I have power back on so I can' mount it on an engine stand yet (IMG:style_emoticons/default/sad.gif) I was in such a rush on friday I didn't get any pics of the whole car so you'll just have to deal with what I took today (IMG:style_emoticons/default/biggrin.gif)
I must say, this car IMHO has the PERFECT amount of horsepower. Enought to smoke the tires for the redneck in all of us, BUT it is very controlable, and can take off from a dead stop without lighting the rubber up. BOLTS in a straight line and still hangs onto the apex like a 914 should and sounds like a mythological beast in heat. This is the best of both worlds (IMG:style_emoticons/default/aktion035.gif) I am hooked (IMG:style_emoticons/default/biggrin.gif) Attached image(s) |
Dr Evil |
Aug 30 2011, 05:39 PM
Send me your transmission! Group: Members Posts: 23,001 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Aftermarket bearing plate is snake oil. The trans obviously suffered a loss of a forward input shaft bearing in the past that lead to the shaft warping the plate due to someone using it and not paying attention to the signs. All the Al plate would do is allow other stuff to break....like your wallet. I dont need them and I dont use them. I install them when asked, but only after I communicate my disbelief in them (IMG:style_emoticons/default/happy11.gif)
jimkelly |
Aug 30 2011, 05:49 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
really - i did not do any hard launches - at worst - i put it in gear got rolling - then peddle to the metal - no side stepping the clutch at 4000 rpm - and did not notice the plate problem when we were rebuilding it - probably did not know what to look for - that said, it shifted pretty damn good - but hey - i remember my wife sitting in copilot seat having to use a bungee cord to keep my car in 5th gear on the hwy on route to0 an ecc years ago : )
here is the deal - 901's are cheap an plentiful - if i like the gear ratios i asked evil to do for me - i will get him to build a few that way - as backups. if i was goi to beat the shit out of my car - i would definitely do a 930 box - but even runnig that inverted is gonna cost $$$ $5000 +- jim Aftermarket bearing plate is snake oil. The trans obviously suffered a loss of a forward input shaft bearing in the past that lead to the shaft warping the plate due to someone using it and not paying attention to the signs. All the Al plate would do is allow other stuff to break....like your wallet. I dont need them and I dont use them. I install them when asked, but only after I communicate my disbelief in them (IMG:style_emoticons/default/happy11.gif) |
Lo-Fi Version | Time is now: 25th May 2024 - 10:51 AM |
