Jim Kelly's V8 re-conversion |
scotty b |
Aug 29 2011, 07:12 PM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
Jim dropped his car off to have me re-do the V8 ( 307 ) install he and Rod did a few years ago. This time around it will be getting the complete Renegade treatment, a new set of Dr. Sheas handi work. Elephant poly bronze bushings, sway bars, 108 c.v.'s. Some BIG ass sway away axles, and a lot of cleaning / detailing. I got started last friday pulling the engine and trans at the last minute before leaving for Matts party. Dr. Evil was going to do a quilie rebuild prior to the party's start. Once we opened up the box, the truth became known. Unfortunaely Jim's intermediate plate was shot. One of the worst Mikes has seen, so Mike took the stack back home to install a good plate, and do the gear swapping. I got to the shop today to find most of the area was tornm to shreds from Irene, so without power or water I couldn't do much other than tear the engine most of the way down. No way to get the flywheel ff until I have power back on so I can' mount it on an engine stand yet (IMG:style_emoticons/default/sad.gif) I was in such a rush on friday I didn't get any pics of the whole car so you'll just have to deal with what I took today (IMG:style_emoticons/default/biggrin.gif)
I must say, this car IMHO has the PERFECT amount of horsepower. Enought to smoke the tires for the redneck in all of us, BUT it is very controlable, and can take off from a dead stop without lighting the rubber up. BOLTS in a straight line and still hangs onto the apex like a 914 should and sounds like a mythological beast in heat. This is the best of both worlds (IMG:style_emoticons/default/aktion035.gif) I am hooked (IMG:style_emoticons/default/biggrin.gif) Attached image(s) |
jimkelly |
Sep 15 2011, 07:25 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
gear stack pic
my plan is to ... delete 1st gear - block it off. 2nd = stock F 3rd = flipped V ( equal to using an R ) 4th = ZD ( move ZD from 5th to 4th position ) 5th = H flipped ( as overdrive ) Attached image(s) |
computers4kids |
Sep 15 2011, 08:08 AM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
gear stack pic my plan is to ... delete 1st gear - block it off. 2nd = stock F 3rd = flipped V ( equal to using an R ) 4th = ZD ( move ZD from 5th to 4th position ) 5th = H flipped ( as overdrive ) Jim, I just run an H and the gears feel just right, with 16" rims with low profile tires. Will you have a higher ratio for 3rd and 4th than stock? It seems like your going have about the same hp and torque and as I do. Mark PS I was going to do something similar with the gears but evil talked me out of it. |
Lo-Fi Version | Time is now: 18th May 2024 - 10:00 AM |
