Type IV header |
Type IV header |
fuch toy |
Apr 24 2003, 12:00 PM
Unregistered |
Well it looks like the 914 header CAN be turned around and fit....almost.....I will need some shims and ticker gaskets. The only problem is that one pipe comes in contact with the oil sender on the bottom of the motor.
Whew...that's gonna save me a few bucks. (IMG:style_emoticons/default/MDB2.gif) |
Gint |
Apr 24 2003, 12:56 PM
Mike Ginter Group: Admin Posts: 16,075 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Will a Kerry Hunter turn around backwards? Seems like with the design the way it is (slip fit into the collector), you could maybe just leave a tube a little short in the collector to make up for a slight bit of length difference? Not having a 2.0/4 here to look at, it's pure WAG...
fuch toy |
Apr 24 2003, 05:18 PM
Unregistered |
Well this one...has stubbies and they are flanged without and angle, so turn it 180 degrees bass ackwards worked. I even got an old supertrapp that bolts right up.....
Just a little less obnoxious than that flowmaster....anyone want it? FREE.... |
Gint |
Apr 24 2003, 05:19 PM
QUOTE Just a little less obnoxious than that flowmaster....anyone want it? FREE.... When can you deliver it? |
fuch toy |
Apr 24 2003, 05:23 PM
Unregistered |
Come get it.....glass of bleach is on the house.... (IMG:style_emoticons/default/blink.gif)
fuch toy |
Apr 24 2003, 07:25 PM
Unregistered |
Kind of looks like the one Tangerine sells....
fuch toy |
Apr 24 2003, 07:27 PM
Unregistered |
Not really, when I look at it....side by side...
Britain Smith |
Apr 24 2003, 07:42 PM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
Where did you get that header, that would work perfectly in my 912 conversion? What is this about the supertrap? Did it mount on that header? Can you post a few more pics of the set-up and details on where you got it from?
-Britain |
fuch toy |
Apr 24 2003, 08:09 PM
Unregistered |
You'd have to ask Chris Campbell about the header.
http://www.nosubstitute.org/914/racecar/images/engine/ His site calls it a Eurorace 4 into one.....never heard of it.... |
fuch toy |
Apr 24 2003, 08:11 PM
Unregistered |
Here's his pic.....
campbellcj |
Apr 24 2003, 09:51 PM
I never did figure out exactly who Eurorace is/was, but they apparently make various engine and exhaust parts for the VW and NARP air-cooled crowd. The stuff was also sold thru FAT.
Brad Roberts |
Apr 24 2003, 09:59 PM
You dont want one Britain...
You can NOT mount a deep sump or a tuna can on the bottom of the engine. B |
fuch toy |
Apr 24 2003, 10:12 PM
Unregistered |
QUOTE(Brad Roberts @ Apr 24 2003, 07:59 PM) You dont want one Britain... You can mount a deep sump or a tuna can on the bottom of the engine. B Well, you could do a tuna can...but you would need to do a little surgery on that one bend.... As it is...I am going to have to dimple one pipe to clear the oil sender.... |
Britain Smith |
Apr 24 2003, 10:23 PM
Yea, I see the problems.
Also, my car is so low that I am going to need something that is tucked a little higher and routed around the engine to the back passenger side so I can mount a muffler around the back for the outlet on the driver side. What is a tuna can? Do you suggest I get a deepsump? -Britain |
ChrisFoley |
Apr 25 2003, 05:41 AM
I am Tangerine Racing Group: Members Posts: 7,926 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
It looks like the collector will stick out the back of a 356, let alone the Supertrapp. Not to mention the ground clearance issues with using a header like that on a rear engine car. You'll have to keep the ride height at about 8" to avoid tearing the header off at every speed bump. (IMG:style_emoticons/default/rolleyes.gif)
Gint |
Apr 25 2003, 06:58 AM
QUOTE What is a tuna can? Do you suggest I get a deepsump? Picture of the \"tuna can\" Courtesy of Campbell It replaces the sump plate. Cheap, easy alternative to a "true" deep sump. |
fuch toy |
Apr 25 2003, 07:52 AM
Unregistered |
I slow for speed bumps and drive ways.....as to the supertrap....think 90 degree bend.
Lo-Fi Version | Time is now: 19th May 2024 - 08:52 PM |
