| jsayre914 |
Sep 2 2011, 09:52 AM
Speed Up !!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,210 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
So my daily driver is now dead on number 3
Engine : Bone stock 1.8 liter w/ L-jet (1974) 2 days ago I am driving as usuall, pushing it pretty hard 4k rpm for about an hour in 5th gear, i notice a loss of power, number three is dead. I pull the plug wire while running and no difference. so I park it overnight and do a valve adjustment in the morning. Number 3 is still dead. I pull the plug and look at it. It is black as hell and not shiny or oily. dull black. I pop in a new plug. still dead. I switch the injector leads from front to back. still #3. I swap injectors from the same side. still #3 this means no compression right? I (IMG:style_emoticons/default/blink.gif) just did the adjustment the night before and it was .006 on intake and exhaust. How can the adjustment be perfect and the cylinder be dead.??? (IMG:style_emoticons/default/confused24.gif) last note: on the dead cylinder, if i pull the injector lead from that one, the rpm drop fatally as if it were only running on 2. but as i said it makes no difference if the plug wire is on or not. What gives?? (IMG:style_emoticons/default/ar15.gif) i guess the motor is comming out again, but what am i looking for (IMG:style_emoticons/default/icon8.gif) |
| VaccaRabite |
Sep 2 2011, 11:01 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,840 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
Compression test. But you know what it is gong to say. Leakdown test will show you where it is leaking (head, valves or rings).
Is it rattling or knocking? Of course I think you should stop effort into your doomed 1.8 and build the 2056. Zach |
| Drums66 |
Sep 2 2011, 11:32 AM
914 Rudiments ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
Compression test. But you know what it is gong to say. Leakdown test will show you where it is leaking (head, valves or rings). Is it rattling or knocking? .......Echo-.....is it rattling or knocking?(to give a more accurate internet diagnosis) (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/bye1.gif) |
| underthetire |
Sep 2 2011, 11:40 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Was the #3 exhaust valve adjuster further out than the rest? Thats usually a pretty good give away of a burned/sunken valve. Ask me how i know..
| r_towle |
Sep 2 2011, 11:59 AM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Have you checked that your number 3 spark plug is firing by grounding out the body of the plug while cranking the motor?
How is the distributor cap? How is the rotor? How are the grounds for the injectors? Are you getting fuel at that injector? Sounds like it may be less complicated???? Rich |
| markb |
Sep 2 2011, 12:44 PM
914less :( ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,450 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California
Plug wire?
| jsayre914 |
Sep 2 2011, 12:55 PM
engine is knocking.
plug is new, wire gives a good arc when touched to ground. compression tester is lost in garage. (will find) when i did the valve adjustment on that cylinder it was a bit tight but nothing out of the ordinary. It was really close thanks for the imput (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/popcorn[1].gif) |
| Dave_Darling |
Sep 2 2011, 07:05 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,326 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
How does the starter sound? If you really do have a dead hole, the starter won't make noise when that piston is at TDC. So the starter will go "RR-RR-RR-..-RR-RR-RR-.." That's when I figured out about my last dropped valve seat.
--DD |
| Dr Evil |
Sep 3 2011, 07:55 PM
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region
Having had my hands on and in that 1.8 of your, I echo the sentiment I told you years ago. Build that damn 2056 already and stop pissing away time and money on that tired 1.8 grenade.
| jsayre914 |
Sep 4 2011, 09:01 AM
stop pissing away time and money on that tired 1.8 grenade. (IMG:style_emoticons/default/sad2.gif) (IMG:style_emoticons/default/poke.gif) Motor comes out Tues evening |
| hot_shoe914 |
Sep 4 2011, 09:25 AM
on ramp passer ![]() ![]() ![]() ![]() Group: Members Posts: 3,807 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None |
stop pissing away time and money on that tired 1.8 grenade. (IMG:style_emoticons/default/sad2.gif) (IMG:style_emoticons/default/poke.gif) Motor comes out Tues evening (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) |
| saigon71 |
Sep 4 2011, 11:55 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,019 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region
Excellent! (IMG:style_emoticons/default/beerchug.gif) I look forward to the 2056 build thread. (IMG:style_emoticons/default/popcorn[1].gif)
| jsayre914 |
Sep 5 2011, 10:39 AM
Thank you Zach (Vaca Rabbite) and Mike (Kirmizi)
They just offerd to rip into my car with me tommorow. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/biggrin.gif) but, I have a soccer game after school and its not gonna happen. It is amazing the things that club members will do for others. I didnt even ask for help (IMG:style_emoticons/default/biggrin.gif) Thanks guys !!! (IMG:style_emoticons/default/first.gif) |
| Kirmizi |
Sep 5 2011, 08:25 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 836 Joined: 12-February 06 From: Wyoming, US Member No.: 5,568 Region Association: None |
Next time Joe! Or better yet, have the 2056 built by the time I come back!!
Mike (IMG:style_emoticons/default/beerchug.gif) |
| jsayre914 |
Oct 5 2011, 09:46 AM
this means no compression right? I (IMG:style_emoticons/default/blink.gif) just did the adjustment the night before and it was .006 on intake and exhaust. How can the adjustment be perfect and the cylinder be dead.??? (IMG:style_emoticons/default/confused24.gif) Let me tell you Joe, First you should not be enjoying the "Raging Bitch" while adjusting your valves. You could get some dirt in your bottle, or, you could totaly #$%# up on that paticular valve. Heck you could make both of the valves on #3 too tight. (IMG:style_emoticons/default/chair.gif) Second, you should try the Captains method using a felt tip marker and doing the entire adjustment without even taking the distributor cap off. (IMG:style_emoticons/default/smilie_pokal.gif) Thanks Capt it now runs like a champ. I was ripping up the pavement on my way in to work this morning. (IMG:style_emoticons/default/driving.gif) I even passed a boxter going "slightly faster" then he was. (IMG:style_emoticons/default/laugh.gif) Its turning into a pretty good day (IMG:style_emoticons/default/shades.gif) p.s. This is the first time I have ever responded to my own post (IMG:style_emoticons/default/biggrin.gif) |
| jsayre914 |
Oct 10 2011, 11:10 AM
dead again.... (IMG:style_emoticons/default/sad.gif) .... 300 miles later.
(IMG:style_emoticons/default/dry.gif) at least i only have 60 miles left to get home (IMG:style_emoticons/default/blink.gif) |
| VaccaRabite |
Oct 10 2011, 12:50 PM
Joe is brave. I have off and offered to tow him home but he elected to drive her back on 3.
| jsayre914 |
Oct 10 2011, 01:35 PM
| jsayre914 |
Oct 10 2011, 02:39 PM
(IMG:style_emoticons/default/idea.gif) Do you guys think its possible to adjust the valves on that one cilinder without jacking the car. It is paralel parked but i got about 2-3 feet in front and back, i am pretty sure i could squeez my head in front of the tire pop the cover and tweak the valve. assuming i am about to drop the seat, i would much rather go out with a bang than a put put put...
(IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/stirthepot.gif) |
| VaccaRabite |
Oct 10 2011, 04:12 PM
Dude.
You got 300 miles last time. Its done. Pull it. Besides, I need the intake parts from it. (IMG:style_emoticons/default/smile.gif) Zach |
Lo-Fi Version | Time is now: 6th March 2026 - 06:19 AM |
