FERODO brake pads, enlarging retaining pin hole |
Part Pricer |
Jul 13 2004, 06:23 AM
Believe everything I post Group: Benefactors Posts: 1,825 Joined: 28-December 02 From: Danbury, CT Member No.: 35 |
I was rummaging through my parts inventory last night when I came across something that I forgot I had, particularly some NOS Ferodo brake pads. I've got a set for both front and rear.
Well, I started to do some investigation on these. The Bird catalog lists these as NLA. But, I was intrigued by the description... QUOTE FERODO pads offer excellent braking characteristics including less brake dust, less noise, more longevity, and better braking performance. All around, a better pad and worth the upgrade. We recommend these for the weekend racer, or someone looking for a little better performance on the street. To use Mintex rear pads, you must have one retaining pin hole enlarged. First question, are these pads that much better as described? Second question, the rear pads do need to have one of the retaining pin holes enlarged to be used in the stock 914-4 rear calipers. Does anyone know the best procedure for doing this? |
ChrisFoley |
Jul 13 2004, 06:30 AM
I am Tangerine Racing Group: Members Posts: 7,933 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
The slow way - file (rat tail) by hand, with a pin handy to check your progress.
The fast way - a long, narrow carbide burr in a die grinder, but this requires lots of skill to avoid having it get away from you and chew up the hole, giving you an unpleasant feeling in your arms at the same time. (IMG:style_emoticons/default/sawzall-smiley.gif) (not quite the right smiley) |
Lo-Fi Version | Time is now: 28th May 2024 - 03:52 AM |
