not so typical build |
yellowporky |
Sep 3 2011, 10:31 PM
Member Group: Members Posts: 427 Joined: 18-October 09 From: Martinez, Ca. Member No.: 10,948 Region Association: Northern California |
I thought is was time to start a build thread now that it is clear the car will be completed.
The project started as a 1975 1.8 in good condition. Here are the specs for the car. - Audi 2.7tt v6 with Vems standalone ecu - Boxster (Audi 012) 5-speed transmission - F&R suspension from 993 This is how the car has sat for about 10 years |
Mike Bellis |
Sep 4 2011, 08:13 PM
You could do a simple ghetto insulation. Get some rolls of heavy paper and Aluminum foil. then wrap several alternating layers; Aluminum, paper, Aluminum, paper... Wrap it tight and put 6-7 layers on it. Works very well. I would also recommend Aluminum electrical conduit for coolant tubes (available at electrical wholesale house) It will conduct less heat into the cabin than steel or copper.
Lo-Fi Version | Time is now: 18th May 2024 - 08:05 PM |
