Door panel plastic water barrier |
biker bob |
Sep 4 2011, 10:34 AM
Member Group: Members Posts: 53 Joined: 25-March 09 From: Eureks Springs Ar. Member No.: 10,200 Region Association: Southwest Region |
Replacing the plastic that keeps the water off the door panel. What do you use to attach the plastic to the inter door? Something that will allow me to remove the plastic in the future. Thanks
budk |
Sep 4 2011, 10:37 AM
Yes! It's a Bumblebee! Group: Members Posts: 678 Joined: 24-July 10 From: Hickory, PA Member No.: 11,970 Region Association: MidAtlantic Region |
I always use RTV. Get one that sets up as quickly as possible if you go that route.
Tom |
Sep 4 2011, 10:40 AM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
julian914 |
Sep 4 2011, 10:41 AM
Newbie Group: Members Posts: 11 Joined: 27-December 10 From: TX Member No.: 12,525 Region Association: None |
I have used and suggest butyl tape. it will make a water/air tight seal which can be pulled off with no residue if you have too. Easiest place to buy it is through fiberglass supply places because it is used for vacuum forming parts. It may be available in other places, but I’m not sure.
Black22 |
Senior Member Group: Members Posts: 886 Joined: 1-November 07 From: Creswell, OR Member No.: 8,290 Region Association: Pacific Northwest |
I used double sided scotch tape. Easily applied and you can take the plastic off and on easily. When it's not sticky anymore, apply some more. I've easily taken the plastic off 10 or more times and the first round of tape still holds like new. It's a clean install too.
cary |
Sep 5 2011, 07:07 AM
I have used and suggest butyl tape. it will make a water/air tight seal which can be pulled off with no residue if you have too. Easiest place to buy it is through fiberglass supply places because it is used for vacuum forming parts. It may be available in other places, but I’m not sure. Ditto, you can get it a NAPA. Comes in a roll with a tape backing for installation. |
vtursi60 |
Sep 5 2011, 07:09 AM
Newbie Group: Members Posts: 11 Joined: 11-February 11 From: Florida Member No.: 12,696 Region Association: None |
SLITS |
Sep 5 2011, 07:32 AM
spray glue, Permatex hi-tack gasket sealant ... anything that sticks it to the door
76-914 |
Sep 5 2011, 08:51 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,500 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Is this where I stick my 2 cents in? I used contact cement. If you buy it in the small brown glass bottle your getting screwed. Lowe's and HD have it in pt. cans and it is 5 times cheaper. You just have to look for it. Apply 1/2" band with small acid brush then lay down the plastic. Just as others have mentioned; you can remove and replace the membrane several times w/o reapplying adhesive.
ellisor3 |
Sep 5 2011, 10:15 AM
HPWhore Group: Members Posts: 811 Joined: 23-October 08 From: Fleming Island, Florida Member No.: 9,683 Region Association: South East States |
If you don't care about it being original, I used fiberglass resin and coated the entire panel. Never have to worry about water and makes it stronger.
Lo-Fi Version | Time is now: 15th May 2024 - 12:43 AM |
