Weber vs. L-tronic, HP limits |
qa1142 |
Jul 13 2004, 06:45 PM
Whiplash Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
OK, how would current 1.8L EFI compare to single weber 32/36 of to a pair of IDF 40's?
I'm not going radical, can I get to 9.5 to 1 and some cam with the EFI? How much power vs. 32/36 or vs. IDF's? thanks |
Jake Raby |
Jul 13 2004, 06:58 PM
The 32/36 is a terrible carb! It only flows 180 CFM Vs. the Weber 40 at 212 CFM per carb, even with a 28mm venturi.
All that extra air means better drivability and gas mileage. Single carbs suck. |
qa1142 |
Jul 13 2004, 07:01 PM
any idea what stock 1.8 EFI could flow?
Jake Raby |
Jul 13 2004, 07:20 PM
airflow doesn't matter that much with EFI, since the air does not have to be atomized..
Lets just say that, its not enough to build a safe performance engine- thats the best way to explain it. If you want FI, wait for Kit Carlson to make his set up attainable, and then go for it.... I'm putting FI back on the 912E, and ONLY because of his system. |
thomasotten |
Jul 13 2004, 07:32 PM
Senior Member Group: Members Posts: 1,544 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 |
What is unsafe about fuel injection?
Jake Raby |
Jul 13 2004, 07:36 PM
If it leans out at ANY RPM, you may aw well open the wallet and start over..
when you have to purposely build the engine inefficient just to keep the injection happy-it is just not cool. This has been discussed all over the net, and I won't go over it all again when all the searches work so well on this and other forums.. |
thomasotten |
Jul 13 2004, 07:44 PM
Ok, thanks, I thought you meant unsafe as in high pressure fuel lines busting and causing 914 to go aflame.
jgiroux67 |
Jul 13 2004, 08:32 PM
Guitar Shredder Group: Members Posts: 593 Joined: 4-June 04 From: Turlock, CA Member No.: 2,157 |
Jake,
What is your opinion on using dual webers on a stock 73 2.0L? What would be better to use 40's or 44's. How much of a performance increase would it give in hp,tq, and throttle response? Would it even be worth it? -Josh |
Jake Raby |
Jul 13 2004, 11:06 PM
A 100% bone stock engine loses a little throttle response with carbs, mainly becaus eof the suck ass camshaft! 40s works well on a stocker, but 44s can be detuned to work well and allow for expansion later.
jgiroux67 |
Jul 13 2004, 11:23 PM
QUOTE(Jake Raby @ Jul 13 2004, 09:06 PM) A 100% bone stock engine loses a little throttle response with carbs, mainly becaus eof the suck ass camshaft! 40s works well on a stocker, but 44s can be detuned to work well and allow for expansion later. So what cam shaft would you advise and how much quicker of feel would it have with it and the 44's |
Aaron Cox |
Jul 13 2004, 11:36 PM
i have 44's on a 2.0 w/ a mild cam. (forgot specs, dad said it was mild compared to cams available...little overlap, mild lift) runs great above 2 k, my idle jets are too large, so i need to change them out for smaller ones.
jake. is there a good config of jets i could swap for great drivability i bought 2 new 44's (so stock config) so i assume i have 55 idles, whats a good base line to start with? (IMG:style_emoticons/default/confused24.gif) |
Jake Raby |
Jul 14 2004, 12:21 AM
I have 43 camshafts that we use effectively with carbs... No two drivers or engines or even cars should be the same...
Camshaft selection must be made based upon the rest of the engine- camshafts are always chosen AFTER everything else. For a weber 44 with a stock 36mm vent try this 55 idle 135 main F11 emulsion 200 air corrector Most carbs come jetted way too rich, these jets are what 95% of my engines from 2056- 2615 really like. |
Aaron Cox |
Jul 14 2004, 08:19 AM
thanks...ill use that as a baseline (IMG:style_emoticons/default/wink.gif)
Jake Raby |
Jul 14 2004, 08:29 AM
what size is the engine? I may have a better combo if you have something that is stock or near stock with 44s
Aaron Cox |
Jul 14 2004, 08:40 AM
QUOTE(Jake Raby @ Jul 14 2004, 07:29 AM) what size is the engine? I may have a better combo if you have something that is stock or near stock with 44s its a 2.0 w/ euro flat pistons. bought brand new weber 44's. havent changed anything on them. a mild carb cam. |
Jake Raby |
Jul 14 2004, 09:11 AM
Ok, this one is better for you
32mm vents 125 mains 50 idles F11 200 air Timing at 28-30 BTDC @ 3500 RPM |
seanery |
Jul 14 2004, 09:19 AM
hey carb man, how bout this one:
96mm 8.9:1 pistons webcam 494 Weber 40's this was running really rich before (with euro 94s), have to go look see what's in it now. |
Aaron Cox |
Jul 14 2004, 09:31 AM
QUOTE(Jake Raby @ Jul 14 2004, 08:11 AM) Ok, this one is better for you 32mm vents 125 mains 50 idles F11 200 air Timing at 28-30 BTDC @ 3500 RPM pefect. thanks jake (IMG:style_emoticons/default/smile.gif) |
Jake Raby |
Jul 14 2004, 10:15 AM
Use the same specs as above for the 32mm vents..
seanery |
Jul 14 2004, 11:03 AM
Thanks Jake!
It's too bad all you do is push your product on everyone. I really wish you were more involved in what others were doing! (IMG:style_emoticons/default/wink.gif) Your presence is greatly appreciated here. |
Lo-Fi Version | Time is now: 15th May 2024 - 03:46 PM |
