How to remove sandwich adapter for external oil cooler? |
JmuRiz |
Sep 6 2011, 08:42 AM
914 Guru Group: Members Posts: 5,425 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
I have a sandwich cooler on my 2.0 that leads to an external oil cooler, it was on there before I bought the car.
Is there a trick to remove sandwich adapter from where the oil filter spins on? I want to make sure I don't mess something up as it's the first time I've delt with a sandwich adapter. Thanks for and tips. Nathan |
Sep 6 2011, 09:06 AM
914 Idiot Group: Members Posts: 14,984 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
IIRC, there should be a nut at the bottom of the adaptor after you pull the filter off. It threads into the filter flange, and has threads that the filter itself threads onto.
It may be that there is more than one kind, but that is what I have seen. --DD |
type47 |
Sep 6 2011, 09:18 AM
delete
This post has been edited by type47: Sep 6 2011, 09:21 AM |
Cap'n Krusty |
Sep 6 2011, 09:57 AM
The tubular stud must also be replaced with a stock part, as it's too long for just the filter. Best to have the necessary parts (as well the correct internal pipe wrench) on hand before you do the work.
The Cap'n |
mightyohm |
Oct 28 2011, 08:52 PM
Does anyone know what size socket I need to remove the threaded piece? I don't have anything that fits it - is it 29mm? (or is it even metric?)
Lo-Fi Version | Time is now: 12th May 2024 - 01:48 PM |
