JmuRiz
Sep 6 2011, 08:42 AM
I have a sandwich cooler on my 2.0 that leads to an external oil cooler, it was on there before I bought the car.
Is there a trick to remove sandwich adapter from where the oil filter spins on?
I want to make sure I don't mess something up as it's the first time I've delt with a sandwich adapter.
Thanks for and tips.
Nathan
Dave_Darling
Sep 6 2011, 09:06 AM
IIRC, there should be a nut at the bottom of the adaptor after you pull the filter off. It threads into the filter flange, and has threads that the filter itself threads onto.
It may be that there is more than one kind, but that is what I have seen.
--DD
type47
Sep 6 2011, 09:18 AM
delete
Cap'n Krusty
Sep 6 2011, 09:57 AM
The tubular stud must also be replaced with a stock part, as it's too long for just the filter. Best to have the necessary parts (as well the correct internal pipe wrench) on hand before you do the work.
The Cap'n
mightyohm
Oct 28 2011, 08:52 PM
Does anyone know what size socket I need to remove the threaded piece? I don't have anything that fits it - is it 29mm? (or is it even metric?)
