removing stock six rt. heat exchanger? |
xsurfer |
Sep 6 2011, 01:19 PM
Member Group: Members Posts: 279 Joined: 4-April 06 From: La Canada, CA Member No.: 5,818 |
Does anyone know which wrench will work on right side heat exchanger? I'm guessing an offset or distributor type wrench. I need to adjust the valves!
Thanks Gene |
GeorgeRud |
Sep 6 2011, 01:23 PM
there is a special "C"shaped wrench that is sold to get at the nuts, in addition to the long allen wrenches.
A 13mm wrench that is bent at a 90 degree angle just past the closed end can also be used. It is much easier to use the correct tools than to try to jury-rig this task. |
Cap'n Krusty |
Sep 6 2011, 02:11 PM
You don't need to remove the heat exchangers to adjust the valves.
The Cap'n |
xsurfer |
Sep 6 2011, 03:34 PM
there is a special "C"shaped wrench that is sold to get at the nuts, in addition to the long allen wrenches. A 13mm wrench that is bent at a 90 degree angle just past the closed end can also be used. It is much easier to use the correct tools than to try to jury-rig this task. Thanks! |
Lo-Fi Version | Time is now: 16th May 2024 - 06:19 AM |
