Does anyone know which wrench will work on right side heat exchanger? I'm guessing an offset or distributor type wrench. I need to adjust the valves! Thanks
Gene
GeorgeRud
Sep 6 2011, 01:23 PM
there is a special "C"shaped wrench that is sold to get at the nuts, in addition to the long allen wrenches.
A 13mm wrench that is bent at a 90 degree angle just past the closed end can also be used. It is much easier to use the correct tools than to try to jury-rig this task.
Cap'n Krusty
Sep 6 2011, 02:11 PM
You don't need to remove the heat exchangers to adjust the valves.
The Cap'n
xsurfer
Sep 6 2011, 03:34 PM
QUOTE(GeorgeRud @ Sep 6 2011, 12:23 PM)
Thanks!
