newdeal2 |
Unregistered ![]() |
Are there any good replacements for the stock FI rails? My stock ones look a bit crude.
These are on eBay but I think they are overkill...yes? |
StratPlayer |
StratPlayer ![]() ![]() ![]() ![]() Group: Members Posts: 3,335 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains ![]() ![]() ![]() |
This is where I mounted my fuel pressure gauge within the engine. It works just fine.
Attached image(s) ![]() |
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
One would think you could mount them in both locations. They're just pressure indicators so they should have no effect on fuel distribution.
Before the regulator tells you your fuel pump is delivering the proper volume to the regulator. After the regulator tells you if your regulator is working properly. No? (IMG:style_emoticons/default/confused24.gif) |
Eric_Shea |
What kind of car is that Jim? (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/biggrin.gif)
(The game is: Find the hidden crests on Jims car) |
mike_the_man |
I like stuff! ![]() ![]() ![]() Group: Members Posts: 1,338 Joined: 11-June 03 From: Regina, Saskatchewan, Canada Member No.: 809 ![]() |
When I add one for adjusting or checking the fuel pressure, I just disconnect the cold start injector and put the guage at the end of that hose.
I believe that after the regulator wouldn't be a good location. Remember that the regulator is like your thumb, so the pressure is actually created before the regulator, between the fuel pump and the regulator. At least thats my understanding. |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,196 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Mike, your understanding is correct.
The "after the regulator" appears to be a small misunderstanding on the part of the poster--his gauge was indeed plumbed in upstream of the regulator, which is why it worked correctly. --DD |
Curvie Roadlover |
Two trunks are better than one! ![]() ![]() ![]() ![]() Group: Members Posts: 2,025 Joined: 29-December 02 From: Southeast Michigan Member No.: 42 ![]() |
Is that a steel braided hose from the airbox to the oil fill? (IMG:style_emoticons/default/blink.gif)
Lo-Fi Version | Time is now: 4th July 2025 - 05:00 AM |
