Whats New at Tangerine Racing Products, most recent product additions |
ChrisFoley |
Sep 10 2011, 10:08 AM
I am Tangerine Racing Group: Members Posts: 7,928 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Link to my Whats New Page
My most recent additions are: 1) Sideshift Linkage Kit - replaces the stock shift rod under the engine. No welding required. Kits are available for -4 and -6 cars. Also available for V8 and 915 conversions. Price is $489.95. 2) Firewall Spherical Bearing for the shift rod coming through the tunnel. This is about as easy to install as a replacement stock bushing. For sideshift cars and tailshift cars converted to sideshift. Price is $59.95. 3) 914-4 Cable Linkage for Dual Carbs. Universal kit fits a variety of setups including ITBs. Retains the stock throttle cable. Price is $329.95. Prices include shipping/handling. When multiple items are ordered I generally recalculate the shipping and refund a portion of your payment. Order direct on my website using Paypal or call my office to place a credit card order. 860-643-1550 Edited 05/18/17 to update prices. |
ChrisFoley |
Jun 23 2014, 09:44 AM
Our newest product is for the Type 4 engine oil system.
This pressure relief valve replaces the factory piston and spring located in the bottom of the crankcase near the oil filter. It eliminates the oil cooler bypass portion of the stock oil circuit and raises the peak operating pressure to 70psi. Peak pressure can be raised or lowered by installing a different length piston. The aluminum bore for the pressure relief assembly is well worn after 40 years of operation and often bypasses a significant amount of oil, lowering available pressure to the bearings. Our assembly has a steel sleeve with close tolerance stainless steel piston for many years of troublefree performance. It will cure many high oil temp/low oil pressure issues and is essential for modified engines with external oil coolers - to achieve optimal oil temperature control. A perfect complement to our remote oil cooler kits which are designed to eliminate the stock cooler from the engine. Use the link below to add the pressure relief to your shopping cart. Tangerine Racing Oil Pressure Relief Shopping Cart Button Price: $79.95, shipping included. Feel free to continue shopping on our website: Tangerine Racing Products Edit 05/18/17: price updated |
98101 |
Feb 8 2018, 01:38 AM
Michael in Seattle Group: Members Posts: 373 Joined: 7-October 17 From: Seattle, WA Member No.: 21,495 Region Association: Pacific Northwest |
A perfect complement to our remote oil cooler kits which are designed to eliminate the stock cooler from the engine. I'm intrigued by this. What is the main motivation to eliminate the stock cooler? Reduced load on the oil pump, or another place not to leak? |
ChrisFoley |
Feb 15 2018, 07:39 AM
A perfect complement to our remote oil cooler kits which are designed to eliminate the stock cooler from the engine. I'm intrigued by this. What is the main motivation to eliminate the stock cooler? Reduced load on the oil pump, or another place not to leak? Two reasons to eliminate the stock cooler in my opinion. 1) Inefficiency of the stock cooling system - doesn't remove enough heat from the oil and the crankcase in that location. 2) stock cooler reduces available cooling air for heads/cylinders Load on the pump isn't affected, and there are more possible leak paths with a remote cooler. The factory oil cooling circuitry followed a simple principle of increasing oil flow thru the cooler when the oil got thin enough from heat to lower oil pressure. Modern oils don't follow a straight line viscosity curve so the stock circuitry doesn't perform as it should with today's multi viscosity oils. A stock 2 liter engine maxes out the stock oil cooling system. |
Lo-Fi Version | Time is now: 21st May 2024 - 05:59 PM |
