Joes 2056 build thread, Its Driving again !!!!!!!!!!!!!!!! |
jsayre914 |
Sep 12 2011, 04:32 PM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
I have been searching all the 2056 threads. Their should really be a 2056 for dummies thread (IMG:style_emoticons/default/biggrin.gif)
I plan on building a 2056 D-jet from my stock 2.0 1973 motor. I have been collecting parts since 2009 (IMG:style_emoticons/default/rolleyes.gif) Here is what I got so far: 2.0 motor (havent split it yet) D-Jet system off my 73 4 cleaned & Tested injectors new wiring harness from bowlsby new tps board new hoses rabby 9550 cam kit 1.8 rockers and swivel feet aa 96mm cylinder & pistons I might be forgettin a few things, it has been a while. (IMG:style_emoticons/default/idea.gif) The heads should be sent out within the week to be checked and prepared with new seats, valves, etc. And I will be splitting the case open this week also. All the cool kids are doing it (IMG:style_emoticons/default/smile.gif) What other thing do I need to purchase as I begin??? gaskets, bearings, flywheel ??? (IMG:style_emoticons/default/confused24.gif) also what tools are required other than the basic tools? I never done this before (IMG:style_emoticons/default/hide.gif) thanks Joseph |
yeahmag |
Sep 12 2011, 06:10 PM
Advanced Member Group: Members Posts: 2,421 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
I think these days you will need to buy a "cam kit" from Jake. That will include everything you need to do the job. You will also need to budget for lot's of machining. You may consider things like:
* Full flow * Type I oil pump * External Oil Cooler * Complete Gasket Kit * Cam and Main Bearings * Rebuild the heads with SS valves, upgraded springs, and keepers * Dynamic balance of all components * Resurface flywheel * Replace clutch and pressure plate (prior to balance job) * Does your MPS hold vacuum? * Got all the tools to do the job? - Head CC'ed - Valve train geometry - Deck Height - Torque wrenches (including inch pound) No wonder my garage is so full... |
Lo-Fi Version | Time is now: 11th May 2024 - 01:56 PM |
