Joes 2056 build thread, Its Driving again !!!!!!!!!!!!!!!! |
jsayre914 |
Sep 12 2011, 04:32 PM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
I have been searching all the 2056 threads. Their should really be a 2056 for dummies thread (IMG:style_emoticons/default/biggrin.gif)
I plan on building a 2056 D-jet from my stock 2.0 1973 motor. I have been collecting parts since 2009 (IMG:style_emoticons/default/rolleyes.gif) Here is what I got so far: 2.0 motor (havent split it yet) D-Jet system off my 73 4 cleaned & Tested injectors new wiring harness from bowlsby new tps board new hoses rabby 9550 cam kit 1.8 rockers and swivel feet aa 96mm cylinder & pistons I might be forgettin a few things, it has been a while. (IMG:style_emoticons/default/idea.gif) The heads should be sent out within the week to be checked and prepared with new seats, valves, etc. And I will be splitting the case open this week also. All the cool kids are doing it (IMG:style_emoticons/default/smile.gif) What other thing do I need to purchase as I begin??? gaskets, bearings, flywheel ??? (IMG:style_emoticons/default/confused24.gif) also what tools are required other than the basic tools? I never done this before (IMG:style_emoticons/default/hide.gif) thanks Joseph |
Dr Evil |
Jan 19 2012, 07:06 PM
Send me your transmission! Group: Members Posts: 22,995 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Bead blast! Ah yes, make sure you clean the case out thoroughly! All the passages and such. You dont want that grit getting into your running parts.
tscrihfield |
Jan 19 2012, 07:11 PM
Drive Fast and Take Chances Group: Members Posts: 643 Joined: 8-September 10 From: Amelia Ohio Member No.: 12,156 Region Association: None |
Bead blast! Ah yes, make sure you clean the case out thoroughly! All the passages and such. You dont want that grit getting into your running parts. (IMG:style_emoticons/default/agree.gif) I would spend a ton of time cleaning that thing to avoid any loose grit getting into the engine when complete! I used to use pipe cleaners that are really long or take out all of the oil galley plugs and run a 22 cal barrel brush through it! |
Lo-Fi Version | Time is now: 12th May 2024 - 12:58 AM |
