Inner long Chassis Stiff Kit install, the complete photo documentary |
Trekkor |
Jul 18 2004, 11:44 PM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
O.K. folks, here it is from start to finish:
First you must remove the seam sealer and body tar from the inside corner of the longs. Attached image(s) |
Trekkor |
Jul 18 2004, 11:45 PM
It is very thick in the corners.
Attached image(s) |
Trekkor |
Jul 18 2004, 11:48 PM
notice the bead of seam sealer that must come out so the sheet metal can fit to the floor pan tight.
Attached image(s) |
Trekkor |
Jul 18 2004, 11:49 PM
another
Attached image(s) |
Trekkor |
Jul 18 2004, 11:51 PM
an air chisel works very well to remove the material
Attached image(s) |
Trekkor |
Jul 18 2004, 11:53 PM
the width of the chisel point using careful, short bursts will quickly break out the tar.
Attached image(s) |
Trekkor |
Jul 18 2004, 11:54 PM
tar out
Attached image(s) |
Trekkor |
Jul 18 2004, 11:56 PM
without removal of the seam sealer and tar the sheet metal panels will not fit properly.
Attached image(s) |
Trekkor |
Jul 18 2004, 11:57 PM
passenger side drops right in.
Attached image(s) |
Trekkor |
Jul 18 2004, 11:59 PM
driver side in. the area around the e-brake handle needs to be worked to fit the contour (IMG:style_emoticons/default/smash.gif)
Attached image(s) |
Trekkor |
Jul 19 2004, 12:01 AM
more (IMG:style_emoticons/default/smash.gif)
I like to grind the edges for a good bite with the welder Attached image(s) |
Trekkor |
Jul 19 2004, 12:03 AM
the inside corners need to be bent and worked into place (IMG:style_emoticons/default/smash.gif)
Attached image(s) |
Trekkor |
Jul 19 2004, 12:04 AM
other side
Attached image(s) |
Trekkor |
Jul 19 2004, 12:06 AM
back piece in .
3 sided dry fitment. Make sure it fits tight before any welding begins. Attached image(s) |
Trekkor |
Jul 19 2004, 12:11 AM
(IMG:style_emoticons/default/welder.gif)
put the weld in the hole and burn into the car's long. then back fill the holes and make good contact into the long sheetmetal. It takes practice. Use low voltage and fast wire speed. Attached image(s) |
Trekkor |
Jul 19 2004, 12:13 AM
mask off the interior and windows so as not to damage them. Ask me how I know (IMG:style_emoticons/default/headbang.gif)
grind your work Attached image(s) |
jgiroux67 |
Guitar Shredder Group: Members Posts: 593 Joined: 4-June 04 From: Turlock, CA Member No.: 2,157 |
What are the black ovals for that are on the passenger side long's? Are they for access to the heater hose or what?
Trekkor |
Jul 19 2004, 12:17 AM
driver side and ground down
Attached image(s) |
Trekkor |
Jul 19 2004, 12:18 AM
back plate
Attached image(s) |
Trekkor |
Jul 19 2004, 12:20 AM
all three sides tied in (IMG:style_emoticons/default/welder.gif)
Attached image(s) |
Lo-Fi Version | Time is now: 6th May 2024 - 04:09 PM |
