Inner long Chassis Stiff Kit install, the complete photo documentary |
Trekkor |
Jul 18 2004, 11:44 PM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
O.K. folks, here it is from start to finish:
First you must remove the seam sealer and body tar from the inside corner of the longs. Attached image(s) |
Engman |
Jul 19 2004, 08:13 PM
Zoisite Group: Benefactors Posts: 1,349 Joined: 25-March 03 From: New Albany, IN Member No.: 475 |
Rear sways - ground to the car (make sure battery and ECU are disconnected) and just wire wheel or gring the edges were you want to weld. You really only need one to start, the others will burn thru after you start to weld. Be sure to touch up with some paint after you are done welding and it has cooled.
M |
Lo-Fi Version | Time is now: 27th May 2024 - 02:03 PM |
