Installing Bursch exhaust, Cat or no Cat ? |
914Rookie |
Jul 19 2004, 12:13 AM
Newbie Group: Members Posts: 38 Joined: 7-May 04 From: La Verne, CA Member No.: 2,033 |
I was installing a Bursch exhaust on my '75 2.0 today and everything was going fine until I started bolting it up and realized that I either had to take the Catalytic converter off the old system or install the Cat bypass tube that is offered. My question is... will the bypass tube be better than using the old catalytic converter and will this have a negative effect on performance/back-pressure ?. Thanks.
Greg |
Joe Bob |
Jul 19 2004, 07:51 AM
Use the bypass unless you need it to pass smog check.
914Rookie |
Jul 19 2004, 10:17 AM
I do need it to pass smog... so I guess it's time to take apart the original exhaust ( something I didn't want to do ), and get this thing installed. Thanks.
Greg |
Allan |
Jul 19 2004, 10:42 AM
Why do you need to pass smog. According to the DMV web site, '75 and older no longer need it. (IMG:style_emoticons/default/mueba.gif)
"How old does a vehicle have to be to qualify for a smog exemption? Vehicles with a year model 30 years old or older are exempt from the smog certification requirements. Example: The calendar year is 2004- 29 = 1975 exempt year model The current calendar year minus 29 equals the year model exempt from smog certification. Note: Hybrid vehicles that use both gasoline and electricity are exempt from smog certification until 2011 it. Check it out at www.dmv.ca.gov |
914Rookie |
Jul 20 2004, 09:34 AM
I think I'll take a drive over to the DMV this week. (IMG:style_emoticons/default/smilie_pokal.gif)
Thanks Greg |
Lo-Fi Version | Time is now: 21st May 2024 - 12:42 AM |
