Relay Board Wiring Mess, PO's Rewire - Need A Little Help |
bandjoey |
Sep 25 2011, 09:00 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
The PO cut the Yellow Wire where it comes from below the relay board up to the pin connector and spliced on a 12" red wire, (#1)and then taped off the end, so it's a dead wire. (IMG:style_emoticons/default/blink.gif)
He then added a red wire from the ignition switch, through the firewall, (#2) and tied it into the yellow wire going into the wire harness moving down towards the starter. What would I do to make this right? It's a '73 original 1.7, switched by the PO to a 1.8 with carbs, and I'm switching that to a 2.0 with carbs and want to get the red wire off the ignition switch. Also, in the other picture, he cut off a Blue wire and taped it off. Where does this go and what does it do and do I need it? Attached image(s) |
Lo-Fi Version | Time is now: 24th May 2024 - 12:56 PM |
