push rod tube seals |
ruddyboys |
Jul 20 2004, 12:22 PM
Hummel eigentümer Group: Members Posts: 594 Joined: 3-March 04 From: Monroe, NY Member No.: 1,749 Region Association: North East States |
My old pushrod tube "O" rings were very loose fitting on the head size (red) the block side were tight. Picked up a new set from the Bird and the fit the same, loose at the head end. When I tried to install them the ring would pull out and curl under the lip. Why? I have the old set, should I try the black ones on top too. '70 1.7 now 2056
Cap'n Krusty |
Jul 20 2004, 02:15 PM
I you have early pushrod tubes and later heads, this'll be a problem. Early heads took a smaller OD on the outer end. Different seals, too. HTH, The Cap'n
Jake Raby |
Jul 20 2004, 03:02 PM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
yep, capn is right. The early 1.7 had 1mm smaller P/R tubes and the bores in the heads are also diferent. The case is the same however..
You can bore the heads for larger tubes and solve the issue, else you'll have to have the correct seals which are NLA as far as I know.. I'd use the old seals and seal them up with my teflon sealant.. |
Toast |
Jul 20 2004, 03:03 PM
Not bad for carrying sway bars. Group: Members Posts: 3,377 Joined: 20-January 04 From: Las Vegas Member No.: 1,580 Region Association: Southwest Region |
If you have alunimum push rod tubes, they are probably no longer any good.
I had push rod tubes in my 1776 VW engine. From what I was told happened to mine, after time of heating and cooling, they eventually expand and dont hold the seals properly anymore. Which was why mine were leaking so bad. But then again, who said VW mechanics knew what they were talking about. (IMG:style_emoticons/default/smash.gif) |
ruddyboys |
Jul 20 2004, 03:07 PM
What is a good Teflon sealant, does it come in a tube?
Dave_Darling |
Jul 20 2004, 03:34 PM
914 Idiot Group: Members Posts: 14,981 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
QUOTE(Toast @ Jul 20 2004, 01:03 PM) I had push rod tubes in my 1776 VW engine. Different animals. The Type I pushrod tubes get sandwiched between the head and the case, which means you have to remove the cylinder head to replace the pushrod tube seals. (Or use one of the collapsible tubes, like they do on 911s.) The ends of the Type I tubes are "accordioned" to provide some pressure to keep the tube ends against the head and case when the engine expands. The Type IV engine has tubes that simply slide through the head and into the case bores. They do not have any "accordion" section, and don't need to expand with heat. That's why we have O-rings that slide along their bores, to allow for that expansion. --DD |
newdeal2 |
Jul 20 2004, 05:18 PM
Unregistered |
Speaking of the seals and Pelican... I just got one of their gasket sets and there are two different seals, a set of green ones for one side and a set of black for the small end. I also have a complete set of the red ones I got last month from Pelican.
Jake says in his video that the green ones are the best . Any advice on what I have? Will the teflon sealant override any faults with the seals? Thanks all, Peter |
Lo-Fi Version | Time is now: 3rd May 2024 - 01:08 PM |
