push rod tube seals |
ruddyboys |
Jul 20 2004, 12:22 PM
Hummel eigentümer Group: Members Posts: 594 Joined: 3-March 04 From: Monroe, NY Member No.: 1,749 Region Association: North East States |
My old pushrod tube "O" rings were very loose fitting on the head size (red) the block side were tight. Picked up a new set from the Bird and the fit the same, loose at the head end. When I tried to install them the ring would pull out and curl under the lip. Why? I have the old set, should I try the black ones on top too. '70 1.7 now 2056
newdeal2 |
Jul 20 2004, 05:18 PM
Unregistered |
Speaking of the seals and Pelican... I just got one of their gasket sets and there are two different seals, a set of green ones for one side and a set of black for the small end. I also have a complete set of the red ones I got last month from Pelican.
Jake says in his video that the green ones are the best . Any advice on what I have? Will the teflon sealant override any faults with the seals? Thanks all, Peter |
Lo-Fi Version | Time is now: 18th May 2024 - 08:04 PM |
