Front trunk Floor pan, Progress thread |
peteyd |
Sep 27 2011, 01:31 PM
Senior Member Group: Members Posts: 707 Joined: 27-March 08 From: Elora, Ontario, Canada Member No.: 8,858 Region Association: Canada |
Alright, I spoke a while back that I was going to start producing the Front trunk pan. I already have all the steel and all the CAD work done, so all I need to do is prep the steel and start cutting!
I wanted to start a thread here for all to follow the progress and also to get a better idea of what goes on at Restoration Design. I am the one in charge of designing and making all the dies here for the 914, 911, 912, and 356's. I have only made two small dies( pedal cluster support, seat mount bracket) for the 914 so far so I wanted to make something else that was in need. I started with an NOS full floor pan. The one that runs from the firewall all the way to the front trunk pan. Brought that away to get a digital scan and then from there I designed the male and female halves of the die. |
peteyd |
Jun 21 2012, 02:41 PM
Time for an update.
We managed to load the die into the press yesterday. There is a total of ten nitrogen cylinders that have 1800 psi in them. They hold up the draw pad higher than the male half of the die. When the female half of the die comes down, it first clamps the sheet metal between the draw pad and the female half of the die. The press then goes into high pressure mode and starts to compress the nitrogen cylinders. (BTW, this press has a maximum of 500 tons of pressure.) This process makes sure that the sheet metal is clamps around the perimeter and in theory should make for less wrinkles and folds. Sometimes different amounts of pressure need to be placed in different areas. You can see in the picture that there is still wrinkling. We only did one stamping so far. Now we have to test out different amounts of pressure in different spots, as well as different blank shapes and sizes. It might take a couple days to fine tune it, and get a perfect part. There are still holes in the pan for drainage and for the vertical tubes under the headlight buckets. There are some edges at the front that need to be hammer formed as well. So once we have stamped a good part, that still needs to be done. |
Niklas |
Jun 21 2012, 03:24 PM
Porsche 914 Sweden Group: Members Posts: 366 Joined: 20-June 09 From: Sweden - Skivarp Member No.: 10,488 Region Association: Scandinavia |
Looking good!!
Maybe oil the sheet metal when you press it so it will form smoother? Niklas |
sixnotfour |
Jun 21 2012, 03:46 PM
914 Wizard Group: Members Posts: 10,433 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
The Blems will make good AC hole patches.
Black22 |
Jun 21 2012, 06:21 PM
Senior Member Group: Members Posts: 886 Joined: 1-November 07 From: Creswell, OR Member No.: 8,290 Region Association: Pacific Northwest |
Jeffs9146 |
Jun 21 2012, 07:04 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
I will take one!!! (IMG:style_emoticons/default/beerchug.gif) |
pjf |
Jun 21 2012, 08:57 PM
Member Group: Members Posts: 132 Joined: 27-September 04 From: Ipswich, MA Member No.: 2,840 |
I will take one!!! (IMG:style_emoticons/default/beerchug.gif) I only need enough to cover an AC hole too. Any chance of you selling the "irregulars"? |
914werke |
Jun 21 2012, 10:19 PM
"I got blisters on me fingers" Group: Members Posts: 10,097 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
You betcha! Ill take that one!
shuie |
Jun 21 2012, 10:25 PM
Member Group: Members Posts: 352 Joined: 17-May 04 From: baton rouge, la Member No.: 2,075 |
peteyd |
Jun 22 2012, 06:19 AM
The parts are not "coined" meaning the die has not come down fully because of the folds. The stamping is not crisp, and I do not want to send out a mediocre product.
I know you only need the AC cutout, but from the picture you cannot see that the lines are not clean and crisp. We will continue to work with it. If we get some stampings that are crisp, but still not good enough as a whole piece, then I will consider selling one. Pete |
pjf |
Jun 22 2012, 06:52 AM
The parts are not "coined" meaning the die has not come down fully because of the folds. The stamping is not crisp, and I do not want to send out a mediocre product. I know you only need the AC cutout, but from the picture you cannot see that the lines are not clean and crisp. We will continue to work with it. If we get some stampings that are crisp, but still not good enough as a whole piece, then I will consider selling one. Pete That makes sense. I didn't consider that the piece wouldn't be fully formed by the creases. Good luck with finishing this piece. I'll definitely be buying one either way. |
ChrisFoley |
Jun 22 2012, 12:41 PM
I am Tangerine Racing Group: Members Posts: 7,933 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Excellent first test! Using that "scrap" piece would be way better than scabbing in a section grabbed from a donor car with 5 layers of paint hiding all the rust. I know some cars that would consider it an upgrade, lol! |
ThePaintedMan |
Jun 22 2012, 01:01 PM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
(IMG:style_emoticons/default/smilie_pokal.gif) Excellent first test! Using that "scrap" piece would be way better than scabbing in a section grabbed from a donor car with 5 layers of paint hiding all the rust. I know some cars that would consider it an upgrade, lol! Yeah! You should sell your scrap/test pieces at a discounted rate to those who don't care so much. That being said, the parts you guys produce are works of art and I understand the need to ensure that every piece that leaves there is up to your standards. Thank you for giving us a place to go - I know many owners of cars who aren't so fortunate. |
JmuRiz |
Jun 22 2012, 01:08 PM
914 Guru Group: Members Posts: 5,431 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Man, I wish you guys made parts for the Mercedes W114/115!!!
obscurity |
Jul 8 2012, 07:37 AM
Member Group: Members Posts: 411 Joined: 24-February 06 From: Atlanta ,GA Member No.: 5,628 Region Association: South East States |
I can't speak for others but I need the engine mount. Any plans for those any time soon. 8) By the way this thread is amazing. I am a closet CNC junkie.
John How about a prestamped hell hole liner (battery side) ?? ....... (IMG:style_emoticons/default/smash.gif) Im not quite sure what you mean. All the pieces for that area are being made currently. Maybe others can chime in but IMO the greater part of most 914s have 'hell hole' corrosion. Mine has the superficial liner completely gone. this is the spot; http://www.914world.com/bbs2/index.php?sho...p;hl=hell++hole There is a kit but it is all flat pieces that needs welding and fabrication in and of itself. If there was a preshaped piece that droped in and spot welded or riveted in place ............ then seam sealed and painted .......... that would be the ticket!!!!! It would be small and you would sell A LOT of them!!! (IMG:style_emoticons/default/aktion035.gif) I did a quick 'title' search for hell hole and got three pages worth right off the bat. (IMG:style_emoticons/default/popcorn[1].gif) Please never rivet a piece of sheet metal over existing rust ! It would only make the problem worse. I do sell these pieces though, which piece still needs to be made? |
RON S. |
Jul 8 2012, 10:46 AM
9140430841, FINALLY RUNNING Group: Members Posts: 1,212 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States |
peteyd |
Jul 9 2012, 08:18 AM
I made some adjustments to the die last week, and we should be trying to stamp another part this week. updates to come... |
MrHyde |
Jul 9 2012, 11:07 AM
Senior Member Group: Members Posts: 525 Joined: 13-October 10 From: Ontario, Canada Member No.: 12,268 Region Association: None |
Excellent.. I just finished with the gas tank bay and rear trunk and painted them on the weekend... moving onto the engine bay next, then I'll be ready for the front trunk.. (IMG:style_emoticons/default/wink.gif)
peteyd |
Jul 10 2012, 03:16 PM
We were working on this die the whole day today. I got rid of the folding in the one corner with the draw bead that I put in as you can see in the first pic.
We have decided that we will sell this part for the guys who need to repair their A/C cutout. The final product will be laser trimmed, have the drain holes below the headlight buckets trimmed out and then the edges hammer formed to replicate the original from Porsche. Im not sure if we are going to cut out the plug sections. We will continue to work out the kinks this week with some more polishing and grinding, but if you want to put in an order for one of the A/C cutout pieces, then give us a call. Pete Here is where there is still some wrinkling. |
SirAndy |
Jul 10 2012, 03:31 PM
Resident German Group: Admin Posts: 41,656 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Very nice ... (IMG:style_emoticons/default/first.gif)
peteyd |
Jul 11 2012, 08:19 AM
We've had a couple calls already for these trunk pans. The die is out of the press for further work. I can sell the few that were stamped yesterday, I think theres only 2 or 3, but there will be more in two to three weeks.
The final product will be a little bit longer, we need to have the laser program fine tuned and some punches made up to put flanges on the part. Pete |
Lo-Fi Version | Time is now: 25th May 2024 - 03:16 AM |
