| MrHyde |
Sep 27 2011, 04:24 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 525 Joined: 13-October 10 From: Ontario, Canada Member No.: 12,268 Region Association: None |
So.... in order to get a bit more room in the garage after the move, so I can start welding on the body i figured I'd work on getting the engine up on a stand an off to the side for a little bit... I have the tranny off and wires/FI stripped off and boxed up and have been taking the sheet metal screws off.. I have 4 that are totally seized on... 3 of them at the intake ports and one on the fan shroud.. I've soaked them with pb blaster and all i've managed to do it mangle the slot in the screw a bit..
I'm inclined to just drill out the screws and tap them afterwards... Before I do this, does anyone have any time tested suggestions to get these buggers off?? If not, does anyone know off hand what size the tap / drill I'll need to use ? Thanks ! Mike |
| VaccaRabite |
Sep 27 2011, 04:29 PM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,864 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
if you have an impact driver you could try tapping them with it. Don't wail on them though. or use a torch and heat them up.
Don't drill them out. If you mess up you could hurt the case. Zach |
| nathansnathan |
Sep 27 2011, 04:32 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,052 Joined: 31-May 10 From: Laguna Beach, CA Member No.: 11,782 Region Association: None |
I would try grabbing the head with vise grips before I tried drilling them out. I've loosened stuck tin screws with a propane torch, too. If you do have to drill and tap they are 6mmx1.0.
| Jeffs9146 |
Sep 27 2011, 04:33 PM
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
I had the same problem and after 3 days of PB I heated them with a torch and used a pair of Vice Grip Plyers and the screw driver at the same time using the wrench more than the screw driver!
3 came out no problem but one broke off in the head. I gave the heads away any way so I never looked at them again! So try the torch heat and vice grip method and take your time letting the PB soak in! |
| tradisrad |
Sep 27 2011, 04:37 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California |
A big screw driver that does not slip/strip out always helps. Bolt extractor set may be helpful.
| Eric_Shea |
Sep 27 2011, 04:42 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
MAPP Torch.
| MrHyde |
Sep 27 2011, 04:51 PM
I just sprayed them (again ) with PB Blaster.. I'll let them soak another night and get some oxygen for my maap torch tomorrow... thanks for the ideas
| wingnut86 |
Sep 27 2011, 05:54 PM
...boola la boo boola boo... ![]() ![]() ![]() Group: Members Posts: 1,054 Joined: 22-April 10 From: South Carolina Member No.: 11,645 Region Association: South East States |
I love PB, it runs through my veins nowadays (IMG:style_emoticons/default/aktion035.gif)
Mapp for sure... |
| bigkensteele |
Sep 27 2011, 05:55 PM
Major Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,200 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States
I just went through this a couple of weeks ago. I found that using a QUALITY screwdriver and a wrench on the screwdriver for torque made them much easier to remove. On the ones that were mangled, I was able to use vice grips of various sizes/styles to get them out. I did not have to resort to heat, but that would have been my next option. The last thing that I would want to do is retap them.
Hopefully, I will be putting it all back together this weekend. There will be anti-sieze on the shiny new ones. |
| r_towle |
Sep 27 2011, 06:11 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Impact screw driver was invented to take out slotted cheese head screws from VW engines.
Get one. http://www.harborfreight.com/impact-screwd...case-37530.html Rich |
| Dave_Darling |
Sep 27 2011, 09:56 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,339 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
I found that having the actual correct size of screwdriver made a huge difference. The largest size flat-head screwdriver that my local Sears carried was the correct size. It's a big mother, and it fits the screws very well. Lean on that and twist it, and they pop loose right away!
--DD |
| majkos |
Sep 27 2011, 10:10 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,370 Joined: 29-February 04 From: Mile High 914 Member No.: 1,729 Region Association: Rocky Mountains |
I found that having the actual correct size of screwdriver made a huge difference. The largest size flat-head screwdriver that my local Sears carried was the correct size. It's a big mother, and it fits the screws very well. Lean on that and twist it, and they pop loose right away! --DD (IMG:style_emoticons/default/agree.gif) Mapp is very good too. One extra step to really break the hold? Ice right after mapp torch heat treatment,ice. Please use sound judgement,there will be snap,crackle and pop, and we're not talking about melting ice, (IMG:style_emoticons/default/biggrin.gif) I don't even want to think about drilling,sucess rate, low |
| TheCabinetmaker |
Sep 28 2011, 04:53 AM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,377 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I'm another for the impact. If you dont have one, your toolbox is incomplete.
| Gint |
Sep 28 2011, 05:45 AM
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,107 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Last time I removed tin, and impact screwdriver got every one of them out. No PB Blaster, no torch, no fuss, no muss. Just out and done.
| larss |
Sep 28 2011, 07:41 AM
Member ![]() ![]() Group: Members Posts: 434 Joined: 10-September 09 From: Sweden Member No.: 10,787 Region Association: Scandinavia |
Had the same problem some weeks ago, a heat gun worked fine for me.
/Lars S |
| sean_v8_914 |
Sep 28 2011, 07:53 AM
Chingon 601 ![]() ![]() ![]() ![]() Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 |
most of the advice above is solid. patience is the key. proper size driver, soak w PB.
...and what Curt said |
| dlestep |
Sep 28 2011, 08:33 AM
I am smilin'... ![]() ![]() ![]() Group: Members Posts: 890 Joined: 15-January 08 From: Sunrise Florida Member No.: 8,573 Region Association: South East States |
...I have a special tool just for that. A B I G fucking screwdriver. I press down with my hand at the top as I slowly twist, and a wooden flat (to keep it from slipping off the screwhead). Sometimes I may need a pair of plyers to grip the square screwdriver shaft as I turn on the stubborn ones. Haven't had one I couldn't remove. Hate those bastards with their stupid single slot. I replace them with real fasteners.
| mikea100 |
Sep 28 2011, 08:50 AM
Member ![]() ![]() Group: Members Posts: 181 Joined: 28-December 09 From: Edison, NJ Member No.: 11,182 Region Association: North East States |
I had the same problem. It took 2 people, my buddy was using vise grips and I was using screw driver at the same time.
| sean_v8_914 |
Sep 28 2011, 09:04 AM
teamwork! love it
| GeorgeRud |
Sep 28 2011, 11:13 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
I've also had better luck using Kroil as a penetranting liquid. Give it time to work overnight, then heat and patience are your friends.
Anti seize when reassembling is also a nice touch to make the next repair easier. |
Lo-Fi Version | Time is now: 14th May 2026 - 01:46 PM |
