My Microsquirt Conversion, MSQ tuning file now posted |
rwilner |
Sep 27 2011, 08:29 PM
No Ghosts in the Machine Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
Ok...
I'm converting my basically stock 2.0L (stock cam, euro Ps and Cs) over to microsquirt. Microsquirt is a megasquirt-derived fuel injection computer that's robot-soldered and factory encased in a weatherproof enclosure. The I/O is implemented as a single, 35-position weatherproof connector. The whole thing is about the size of 2 decks of cards. The system I'm installing was engineered and supplied 100% by McMark. My understanding is that he usually provides these systems for motors that he builds, but I talked him into providing one for me. Below, I will document the install details here for anyone else who talks McMark into selling them a system, or who attempts something similar someday. DISCLAIMER: I won't provide model numbers, prices, or any other info like that in this thread -- please contact McMark directly for those types of details. All I can say is that you get what you pay for and this is a top-notch system that will work for the remaining life of the car. The system provides the following components new:
OK, enough babbling, on to the install! (IMG:style_emoticons/default/chowtime.gif) |
904svo |
Sep 28 2011, 11:28 AM
904SVO Group: Members Posts: 1,118 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
I ran into problems trying to use MAP, the vacuum was not steady enough to tune the VE table. I had to pass a Two Speed Idle test for inspection. I then try to use TPS instead, this also failed inspection test. The TPS/VE table did not know the difference between no-load and load. I then went to MAF using a Ford MAF sensor,
the car now passes inspection as the MAF measures the air flow which is difference between load and no-load. The engine also runs great now it idles at 600 RPM's and is smooth as silk. All these changes were made on a stock 1.7 ltr engine using Megasquirt running MS1-extra software. |
Lo-Fi Version | Time is now: 19th May 2024 - 10:53 AM |
