My Microsquirt Conversion, MSQ tuning file now posted |
rwilner |
Sep 27 2011, 08:29 PM
No Ghosts in the Machine Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
Ok...
I'm converting my basically stock 2.0L (stock cam, euro Ps and Cs) over to microsquirt. Microsquirt is a megasquirt-derived fuel injection computer that's robot-soldered and factory encased in a weatherproof enclosure. The I/O is implemented as a single, 35-position weatherproof connector. The whole thing is about the size of 2 decks of cards. The system I'm installing was engineered and supplied 100% by McMark. My understanding is that he usually provides these systems for motors that he builds, but I talked him into providing one for me. Below, I will document the install details here for anyone else who talks McMark into selling them a system, or who attempts something similar someday. DISCLAIMER: I won't provide model numbers, prices, or any other info like that in this thread -- please contact McMark directly for those types of details. All I can say is that you get what you pay for and this is a top-notch system that will work for the remaining life of the car. The system provides the following components new:
OK, enough babbling, on to the install! (IMG:style_emoticons/default/chowtime.gif) |
McMark |
Oct 22 2011, 10:34 PM
The seal should hang down, and there should be a small upturned section. That upturn hooks under the tin. Try that... (IMG:style_emoticons/default/wink.gif)
rwilner |
Oct 23 2011, 07:17 AM
The seal should hang down, and there should be a small upturned section. That upturn hooks under the tin. Try that... (IMG:style_emoticons/default/wink.gif) i love doing things twice! looks like the engine is coming out and in again today... (IMG:style_emoticons/default/beer3.gif) |
rwilner |
Oct 23 2011, 09:00 PM
Had a fairly productive weekend.
I received Tom's raised fuse block and installed it. It's a raised 4 position fuse block that protects the 4 hot wires connecting to the battery. Installation was a snap while the engine was out, although installing with the engine in place wouldn't be very difficult either. (IMG:https://lh5.googleusercontent.com/-t5Lrfln-NEo/TqTNxgKCfbI/AAAAAAAAAYo/7Bnax_hp-ko/s800/111023_7.JPG) (IMG:https://lh6.googleusercontent.com/-G8RFURDQ2DM/TqTN2moP9TI/AAAAAAAAAZA/LmQzSeuseFU/s800/111023_8.JPG) After I cleaned up a bunch of gunk I found my GA engine number! Also, check out this SWEET plug McMark supplied to clean up the distributor channel. Style and function! (IMG:https://lh6.googleusercontent.com/-o8GV9mtNdOg/TqTNrRcQduI/AAAAAAAAAZM/dRXKHF3G0jM/s800/111023_2.JPG) (IMG:https://lh4.googleusercontent.com/-nXqHlYp2NUs/TqTQ1o_lOrI/AAAAAAAAAZY/lqGDlZa8jbY/s800/111023_13.JPG) My engine impeller was missing 1 fin, so I purchased this very nice one from Mark Heard and popped it in place. Mark also gave me an alternator cooling boot in great shape, which replaced the liquefied one shown earlier in this thread. (IMG:https://lh5.googleusercontent.com/-5Gpm2fjzOyg/TqTQ6iKWnkI/AAAAAAAAAZ0/v7J3C74XOQk/s800/111023_10.JPG) (IMG:https://lh6.googleusercontent.com/-cVM0R9wPsM4/TqTQ2nNXbhI/AAAAAAAAAZk/pfQkxrsV1-g/s800/111023_11.JPG) (IMG:https://lh6.googleusercontent.com/-gQ67xEBUe1c/TqTQ1aAYEcI/AAAAAAAAAZU/ShpTy_8w8CM/s800/111023_12.JPG) (IMG:https://lh6.googleusercontent.com/-XdZnnnQe-yA/TqTQ5MlBqaI/AAAAAAAAAZs/LybXhwF_Wg0/s800/111023_9.JPG) I installed a new engine soundpad from AppBiz (highly recommended) and new engine bay seals from Mikey914. I recommend that unlike me, you do not install the engine seals upside down the first time around... (IMG:style_emoticons/default/smile.gif) (IMG:https://lh4.googleusercontent.com/--fow5GWteyk/TqTNqlARVNI/AAAAAAAAAYI/6iZzg4_calQ/s800/111023_4.JPG) I drilled a hole in the engine tin to run the wires for the O2 brain. I had to determ and reterm the weatherpack connector to feed the wire through the hole, which was a no-brainer. The O2 brain will mount to one of the transmission mounts. I had to relocate the brain because the O2 sensor wire was not long enough and no extension was available or recommended by the manufacturer. I also built a little harness to calibrate the O2 sensor, which is required every 10k miles or once per year. (IMG:https://lh5.googleusercontent.com/-8gFtUU8H_SM/TqTNrRqr9KI/AAAAAAAAAZI/d3i9V6iLpVk/s800/111023_3.JPG) (IMG:https://lh5.googleusercontent.com/-goVOh4W4-94/TqTNyGng3NI/AAAAAAAAAYw/gj7cuclrakU/s800/111023_6.JPG) Now it was time to lure a buddy to my house with a six pack and put the engine back in the car. (IMG:https://lh3.googleusercontent.com/-WYDHQcfz3c0/TqTNxSXJK_I/AAAAAAAAAYg/SBFtdZnzy8Y/s800/111023_5.JPG) Not quite ready to fire the engine, but with some effort this week I should get there by the weekend -- just reconnecting stuff now! |
Lo-Fi Version | Time is now: 19th May 2024 - 12:20 PM |
