My Microsquirt Conversion, MSQ tuning file now posted |
rwilner |
Sep 27 2011, 08:29 PM
No Ghosts in the Machine Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
Ok...
I'm converting my basically stock 2.0L (stock cam, euro Ps and Cs) over to microsquirt. Microsquirt is a megasquirt-derived fuel injection computer that's robot-soldered and factory encased in a weatherproof enclosure. The I/O is implemented as a single, 35-position weatherproof connector. The whole thing is about the size of 2 decks of cards. The system I'm installing was engineered and supplied 100% by McMark. My understanding is that he usually provides these systems for motors that he builds, but I talked him into providing one for me. Below, I will document the install details here for anyone else who talks McMark into selling them a system, or who attempts something similar someday. DISCLAIMER: I won't provide model numbers, prices, or any other info like that in this thread -- please contact McMark directly for those types of details. All I can say is that you get what you pay for and this is a top-notch system that will work for the remaining life of the car. The system provides the following components new:
OK, enough babbling, on to the install! (IMG:style_emoticons/default/chowtime.gif) |
Apr 10 2012, 02:06 PM
messing, no driving....
At least its fun... Rich |
falconfp2001 |
Apr 10 2012, 04:44 PM
Pancho Pantera Group: Members Posts: 451 Joined: 5-December 10 From: Downey, CA Member No.: 12,456 Region Association: Southwest Region |
I just discovered a cool new feature of the MicroSquirt! The latest code revision allows you to toggle between 2 different sets of tuning parameters (VE fuel maps and AFR targets) at the flip of a switch. This means you can set one tune for 87 and another for 93, or one tune for pump gas and another for race gas. I might have to mess with this a bit later... (IMG:style_emoticons/default/idea.gif) I think they mentioned that as a new feature. You can use one of the spare inputs for a switch. hehehe If you didn't see my last post for the Expanded CLT Temps. I fugured out how to load MS2Extra and it works. Gives you a lot of options that the regular firmware does not have. I don't know if it works with MicroSquirt but you can always e-mail DIYAutoTune about it. |
falconfp2001 |
Apr 10 2012, 11:06 PM
I just discovered a cool new feature of the MicroSquirt! The latest code revision allows you to toggle between 2 different sets of tuning parameters (VE fuel maps and AFR targets) at the flip of a switch. This means you can set one tune for 87 and another for 93, or one tune for pump gas and another for race gas. I might have to mess with this a bit later... (IMG:style_emoticons/default/idea.gif) Also the Latest MS Extra code lets you make the tables switch either by software or a hardware switch. Hardware requires some pretty tricky soldering directly to the board. Who's the guy that did you mods? |
rwilner |
Apr 11 2012, 06:35 AM
Also the Latest MS Extra code lets you make the tables switch either by software or a hardware switch. Hardware requires some pretty tricky soldering directly to the board. Who's the guy that did you mods? Jeff Keyzer, mightyohm on this site. In the microsquirt, the flexfuel signal is accessible in the ampseal connector so there's no board soldering required...not sure about megasquirt proper. |
falconfp2001 |
Apr 11 2012, 09:20 AM
Also the Latest MS Extra code lets you make the tables switch either by software or a hardware switch. Hardware requires some pretty tricky soldering directly to the board. Who's the guy that did you mods? Jeff Keyzer, mightyohm on this site. In the microsquirt, the flexfuel signal is accessible in the ampseal connector so there's no board soldering required...not sure about megasquirt proper. The MS Extra is loadable to MicroSquirt. When you run the .bat file to load, it will ask what type of ECU you are using, mega or Micro. |
rwilner |
Jun 17 2012, 05:31 AM
Over 1000 miles on this system now...I'm very pleased with how it's performing.
Attached is my .msq file. It should work with both megasquirt and microsquirt. If any of you use it and have questions, feel free to PM me. (Of course -- use at your own risk.) 24APR12_RTW_914_2L.zip ( 5.4k ) Number of downloads: 200 |
rwilner |
Aug 14 2012, 07:32 PM
Over 1000 miles on this system now...I'm very pleased with how it's performing. Attached is my .msq file. It should work with both megasquirt and microsquirt. If any of you use it and have questions, feel free to PM me. (Of course -- use at your own risk.) 24APR12_RTW_914_2L.zip ( 5.4k ) Number of downloads: 200 Trying the zip file one more time since the last one didn't post correctly. Attached File(s) 24APR12_RTW_914_2L__2_.zip ( 5.4k ) Number of downloads: 70 |
rwilner |
Aug 14 2012, 07:35 PM
Over 1000 miles on this system now...I'm very pleased with how it's performing. Attached is my .msq file. It should work with both megasquirt and microsquirt. If any of you use it and have questions, feel free to PM me. (Of course -- use at your own risk.) 24APR12_RTW_914_2L.zip ( 5.4k ) Number of downloads: 200 Trying the zip file one more time since the last one didn't post correctly. Hm, still empty I emailed sirandy to see if there's any way to post this file to the thread, in the meantime if you want the file, PM me. |
JmuRiz |
Aug 14 2012, 07:55 PM
914 Guru Group: Members Posts: 5,427 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Very cool status updates (see, no one needs facebook!)
I wish microsquirt could individually control 6-cyl...the packaging is so nice. I'll just keep telling myself that's the reason I don't have EFI on my 2.7 engine and my old Benz CIS motor. |
Aug 15 2012, 07:58 PM
Resident German Group: Admin Posts: 41,644 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I emailed sirandy to see if there's any way to post this file to the thread, in the meantime if you want the file, PM me. Ok, try this link: http://www.914world.com/cantnamethisdownlo..._RTW_914_2L.zip (IMG:style_emoticons/default/idea.gif) |
gothspeed |
Jan 18 2014, 09:05 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
Awesome thread (IMG:style_emoticons/default/smilie_pokal.gif) !!! ..... how is this car running now? .... (IMG:style_emoticons/default/sunglasses.gif)
Jan 19 2014, 09:22 AM
He sold it back to the original owner and bought a 911.
gothspeed |
Jan 19 2014, 02:48 PM
He sold it back to the original owner and bought a 911. Why would anyone buy a 911 ? ........ (IMG:style_emoticons/default/screwy.gif) I guess everyone needs to make their own mistakes ..... (IMG:style_emoticons/default/popcorn[1].gif) |
Jan 19 2014, 02:58 PM
He sold it back to the original owner and bought a 911. Why would anyone buy a 911 ? ........ (IMG:style_emoticons/default/screwy.gif) I guess everyone needs to make their own mistakes ..... (IMG:style_emoticons/default/popcorn[1].gif) Hey now... I have a 911 also.... |
gothspeed |
Jan 19 2014, 03:02 PM
He sold it back to the original owner and bought a 911. Why would anyone buy a 911 ? ........ (IMG:style_emoticons/default/screwy.gif) I guess everyone needs to make their own mistakes ..... (IMG:style_emoticons/default/popcorn[1].gif) Hey now... I have a 911 also.... yeah, I had a few ..... back when I did not know any better ..... (IMG:style_emoticons/default/biggrin.gif) |
rwilner |
Jun 28 2016, 07:39 PM
He sold it back to the original owner and bought a 911. Why would anyone buy a 911 ? ........ (IMG:style_emoticons/default/screwy.gif) I guess everyone needs to make their own mistakes ..... (IMG:style_emoticons/default/popcorn[1].gif) Hey now... I have a 911 also.... yeah, I had a few ..... back when I did not know any better ..... (IMG:style_emoticons/default/biggrin.gif) I now have the space to buy another car. Not "Towle barn" space, but enough... Passively looking for a 914 again (IMG:style_emoticons/default/smile.gif) This time, I think I'll actually combine this with a 2056 or a 2270. |
Jun 28 2016, 09:05 PM
I got one for you...
76, green with white interior... Near me, not mine...new paint and interior. Not started in ten years... You can borrow my truck and trailer. Rich |
2mAn |
Jun 28 2016, 10:15 PM
trying to see how long I can go without a 914 Group: Members Posts: 487 Joined: 14-November 13 From: Westchester (Los Angeles) Member No.: 16,644 Region Association: Southern California |
I got one for you... Rich enabler! (IMG:style_emoticons/default/happy11.gif) If I get the car Im looking for I plan to do the same and this is a 2270 |
rwilner |
Jun 29 2016, 06:32 AM
mailmanboise |
Jan 8 2019, 10:56 PM
Newbie Group: Members Posts: 2 Joined: 7-June 18 From: Boise, Id Member No.: 22,200 Region Association: None |
Ive got a 73 with a 1.7 ish motor, I believe its had some jug work done because they have paint pen marks on them. The paperwork I have says that it has a Norris 272 cam. Im running a proper D jet system ( she had twin 40's). Ive had to slighty modify the MPS, at idle Ive got a fluctuations in vacuum as well as low static compression (85 psi on all 4) she has a nice "lop" to her as she idle and it strong all the way thru the power curve. I can chase down my friends 76 914 2.0 going up a hill..
Im interested in doing a microsquirt system, with either a map or maf sensor, I guessing because of the fluctuation of vacuum at idle I may have to go with an MAF sensor. Any advice would be appreciated Rob |
Lo-Fi Version | Time is now: 19th May 2024 - 06:24 AM |
