Problem Starting |
Problem Starting |
914guy |
Apr 25 2003, 02:30 PM
Newbie Group: Members Posts: 46 Joined: 11-April 03 From: Fairfax VA Member No.: 561 |
Hello All~
Well I was up until 4:30am last night, but I can proudly say that the engine is in the car (IMG:style_emoticons/default/biggrin.gif) I connected all of the FI wires, double checked that all of my hoses were connected, poured about 2 gallons of fresh gas in the tank, went to turn the key and ............... NOTHING!!??!?!?!? I get all of the lights on in the car, the battery is fully charged and the ground strap is connected, it just seems like there is no power to the starter. I triple checked all of my wiring and everything appears to be okay. The one thing that could be the source of my problem, is the clutch and shift linkage are not hooked up, although the car is in Neutral and the clutch is depressed all the way to the floor. I am hopefully going to find shifter bushings and a new clutch cable in Hershey on Saturday I assumed any sensors would have been engaged with the clutch in that position. Could the clutch be my problem, does anyone have any other ideas?? Thanks, ~Eric |
Mueller |
Apr 25 2003, 02:35 PM
The car could care less about the linkage and all the other shifter parts.
Do you have voltage at the starter? Do you have voltage at the big yellow wire going to the starter when the key is turned? You can check this at the starter or the relay board. |
Lawrence |
Apr 25 2003, 02:38 PM
Did you check your transmission ground strap? I always seem to forget that one.
-Rusty |
Gint |
Apr 25 2003, 02:56 PM
Mike Ginter Group: Admin Posts: 16,075 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Do the 75's have the seatbelt interlock relay?
Lo-Fi Version | Time is now: 20th May 2024 - 06:07 AM |
