Is this a common rusting spot?, Driver side front jack donut |
jgiroux67 |
Jul 20 2004, 06:11 PM
Guitar Shredder Group: Members Posts: 593 Joined: 4-June 04 From: Turlock, CA Member No.: 2,157 |
Is it common for there to be a lot of rust at the front jack stand donut(or whatever its called) on the drivers side? I did some rust raiding today and found that it is almost completly rusted through.
What is the best way of repairing this? I'll post some pictures as soon as I can |
Jeroen |
Jul 20 2004, 06:19 PM
Yep, the donuts rust easily, cause they are basically open cavities that will fill with crap and trap moisture
Also by using them, the paint gets damaged, so that's a win-win situation (for rust) Best way to fix them is to grind off all the rusted metal and weld in new pieces Dunno if these are available, so you may have to fab new donuts... cheers, Jeroen |
jgiroux67 |
Jul 20 2004, 06:23 PM
Thank you, thats good to hear.
crash914 |
Jul 21 2004, 05:58 AM
its a mystery to me Group: Members Posts: 1,826 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region |
Yes new ones are available from restoration design.....easy fix...not so easy to fix the rust under the other side (battery)
michelko |
Jul 21 2004, 09:42 AM
Senior Member Group: Members Posts: 867 Joined: 30-November 03 From: Germany, Lambsheim Member No.: 1,404 Region Association: None |
Hello,
this is what my driverside donut looked like. (IMG:style_emoticons/default/wacko.gif) the donut is strong but the panel was rusted through. Attached image(s) |
michelko |
Jul 21 2004, 09:44 AM
cut the whole shit out and fixed it with fresch metal
michelko |
Jul 21 2004, 09:46 AM
(IMG:style_emoticons/default/chowtime.gif) ...fresh... (IMG:style_emoticons/default/biggrin.gif)
michelko |
Jul 21 2004, 09:47 AM
doing some welding (IMG:style_emoticons/default/welder.gif)
michelko |
metallwork (IMG:style_emoticons/default/smash.gif)
michelko |
Jul 21 2004, 09:49 AM
metallwork
michelko |
Jul 21 2004, 09:50 AM
and again welding (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/welder.gif)
greetings (IMG:style_emoticons/default/smilie_flagge6.gif) Attached image(s) |
Lo-Fi Version | Time is now: 20th May 2024 - 10:26 PM |
