Its Suspension Time!, anyone with tips tricks? |
cha914 |
Jan 14 2003, 11:52 AM
MUSR 8 - 5lug conversion done wed - drive 500miles thrus Group: Members Posts: 739 Joined: 31-December 02 From: Austin, TX Member No.: 63 |
Starting friday I will be pulling the suspension off the 914 and
- installing Koni sports all around with the fully adj perches in the rear -new poly bushings all around (from weltmeister...street compound) -turbo tie rod kit -new ball joints ...anyway...this is the last part of the 914 that I haven't pulled off the car yet, so its time. any, tips, hints that you have will be much appreciated. I am going to be doing this with the help of a lift and plenty of tools...so I am hoping to knock this out over the weekend...doable? Thanks, Tony |
Jeroen |
Jan 14 2003, 03:53 PM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
I got that one... won't work on the strut/balljoint
Couldn't get the tie-rods off with it either. I used a different tool for the tie-rods. I was scared the tool would break (not good if it's a loaner), but the tie-rod gave first Darn, this stuff can get stuck! Cheers, Jeroen |
Lo-Fi Version | Time is now: 14th May 2024 - 03:30 AM |
