Its Suspension Time!, anyone with tips tricks? |
cha914 |
Jan 14 2003, 11:52 AM
MUSR 8 - 5lug conversion done wed - drive 500miles thrus Group: Members Posts: 739 Joined: 31-December 02 From: Austin, TX Member No.: 63 |
Starting friday I will be pulling the suspension off the 914 and
- installing Koni sports all around with the fully adj perches in the rear -new poly bushings all around (from weltmeister...street compound) -turbo tie rod kit -new ball joints ...anyway...this is the last part of the 914 that I haven't pulled off the car yet, so its time. any, tips, hints that you have will be much appreciated. I am going to be doing this with the help of a lift and plenty of tools...so I am hoping to knock this out over the weekend...doable? Thanks, Tony |
Brad Roberts |
Jan 14 2003, 04:40 PM
I dont use heat.. ever. Your lower ball joints dont always need replacing... so I dont use heat. It cooks the grease and melts the rubber protector.
B |
Lo-Fi Version | Time is now: 13th May 2024 - 04:14 PM |
