Its Suspension Time!, anyone with tips tricks? |
cha914 |
Jan 14 2003, 11:52 AM
MUSR 8 - 5lug conversion done wed - drive 500miles thrus Group: Members Posts: 739 Joined: 31-December 02 From: Austin, TX Member No.: 63 |
Starting friday I will be pulling the suspension off the 914 and
- installing Koni sports all around with the fully adj perches in the rear -new poly bushings all around (from weltmeister...street compound) -turbo tie rod kit -new ball joints ...anyway...this is the last part of the 914 that I haven't pulled off the car yet, so its time. any, tips, hints that you have will be much appreciated. I am going to be doing this with the help of a lift and plenty of tools...so I am hoping to knock this out over the weekend...doable? Thanks, Tony |
cha914 |
Jan 14 2003, 04:56 PM
ok...thats good info...I will plan on at least double your time since its my first try.
Brad...you also mentioned earlier how you cut groves into the poly bushings to hold the grease...you got any pics of this? Thanks for the help, Tony |
Lo-Fi Version | Time is now: 14th May 2024 - 08:58 AM |
