Its Suspension Time!, anyone with tips tricks? |
cha914 |
Jan 14 2003, 11:52 AM
MUSR 8 - 5lug conversion done wed - drive 500miles thrus Group: Members Posts: 739 Joined: 31-December 02 From: Austin, TX Member No.: 63 |
Starting friday I will be pulling the suspension off the 914 and
- installing Koni sports all around with the fully adj perches in the rear -new poly bushings all around (from weltmeister...street compound) -turbo tie rod kit -new ball joints ...anyway...this is the last part of the 914 that I haven't pulled off the car yet, so its time. any, tips, hints that you have will be much appreciated. I am going to be doing this with the help of a lift and plenty of tools...so I am hoping to knock this out over the weekend...doable? Thanks, Tony |
gklinger |
Jan 15 2003, 11:33 AM
doh! Group: Members Posts: 316 Joined: 14-January 03 From: Tempe, AZ Member No.: 146 Region Association: Southwest Region |
QUOTE(Brad Roberts @ Jan 14 2003, 04:24 PM) Just make a spiral path down the inside of them with something resembling a Dremel tool. I use a air grinder and carbide tip. Takes about 10 minutes per bushing. It really helps keep the grease in them. I remember seeing on the PP board a post from someone who had done this, as well as drilling and tapping for zerk fittings. Is this necessary? It sounds like a good idea from the future maintenance aspect, but I'm wondering if it's worth it. If you did this, could you just pump a good grease in there, or would the special poly grease be preferred? Garry |
Lo-Fi Version | Time is now: 14th May 2024 - 01:32 AM |
