Morph Carpet Kit - Perhaps I got a short cut piece?, Passenger side seems to leave a gap? |
ptravnic |
Sep 29 2011, 08:47 PM
Senior Member Group: Members Posts: 1,231 Joined: 27-May 03 From: Chicago, IL Member No.: 747 Region Association: None |
Finally time to start fitting the carpet post paint job. Problem is, I can't seem to figure out how to properly cover the passenger side. Turns out that the passenger side floor piece is either too short or the passenger side bulkhead piece is goo short. (IMG:style_emoticons/default/confused24.gif)
The bulkhead piece has to be fairly high up in order to get to the steering rack cutout but where that piece flows down to the passenger floor it either leaves a gap in front or in back near the seat cross bar. It ends up exposing about 2" worth of floor board. The pic does a better job explaining (the gap is larger than it appears in the pic): FWIW - I thought this link was excellent for placement of each piece: Post describing carpet placement Thanks in advance! -pt |
Valy |
Sep 29 2011, 08:51 PM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
What year is your car? The later models have the foot rest behind the carpet so there should be no gap.
The older models have the foot rest (step type) on the carpet. It looks to me that you have the newer carpet and no footrest under the carpet. |
JRust |
Sep 29 2011, 08:56 PM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
What year is your car? The later models have the foot rest behind the carpet so there should be no gap. The older models have the foot rest (step type) on the carpet. It looks to me that you have the newer carpet and no footrest under the carpet. (IMG:style_emoticons/default/agree.gif) |
ptravnic |
I sent Morph the question but thought I'd ask it here too b/c I know that sometimes James and Heidi get backed up. What year is your car? The later models have the foot rest behind the carpet so there should be no gap. The older models have the foot rest (step type) on the carpet. It looks to me that you have the newer carpet and no footrest under the carpet. This is 1972 chassis and it has the molded Styrofoam piece nestled into the bulkhead area, behind the carpet. If the bulkhead carpet was transparent you would see it. |
montoya 73 2.0 |
Sep 29 2011, 10:12 PM
Lack of consideration to others, and Selfish! Group: Members Posts: 1,791 Joined: 27-October 04 From: Paso Robles, Ca. Member No.: 3,016 Region Association: Central California |
My bulkhead piece was a little long so it was covered by the floor piece.
Tom_T |
Sep 29 2011, 10:21 PM
70-71 with the non adjustable pass. seat are longer & had that separate perlon covered footrest with the "leash" - so that requires the long "early" pass. carpet.
72-76 with adjustable pass. seat is a shorter floor piece, cuz the pass foot board extends further back - so that requires the shorter "late" pass. carpet. So you either have a 70-71 914 with a late carpet, or you used a 70-71 foot board at the pass. footwell in a late 72-76 914. Ask morph for an exchange to a long "early" pass. carpet piece. |
jsayre914 |
Sep 30 2011, 09:45 AM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
looks like yoor missing the foam wedge that is supposed to be behind the carpet against the firewall.
here is a pic of the wedge (i cut a giant rectangle out of mine) Attached image(s) |
jsayre914 |
Sep 30 2011, 09:52 AM
This is the same kit from the same guy, in a 73
Sep 30 2011, 10:44 AM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I had this also.
You want to get the later foam piece (it changed in 72 mid year) or the early carpet. I would go for the later foam piece...its a bit larger. It also does not rust...lol There are lots of them around. RIch |
Sep 30 2011, 12:01 PM
914-6 GT in waiting Group: Members Posts: 19,316 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I have a good one (foam) from a '75. Yours for the cost of shipping. mark
ptravnic |
Sep 30 2011, 04:39 PM
I'm even more confused than ever. I know about the adjustable vs non-adjustable seat thus the early foot rest. Am I now hearing that form fitting foam piece between the carpet and the bulkhead (pictured below) comes in two sizes? (IMG:style_emoticons/default/confused24.gif)
jsayre914 |
Sep 30 2011, 05:20 PM
nsr-jamie |
Sep 30 2011, 08:26 PM
914 guy in Japan Group: Members Posts: 1,182 Joined: 7-November 07 From: Nagoya, Japan Member No.: 8,305 Region Association: None |
I had the same problem like you too, they changed in 72 and you need the longer piece...talk to Morph and he will set you up...all I did was email him and with in a couple of days he mailed me back and told me he was sending out the correct piece. I am sure he will do the same for you. Nice color of carpets by the way.
ptravnic |
Oct 1 2011, 12:05 PM
I had the same problem like you too, they changed in 72 and you need the longer piece...talk to Morph and he will set you up...all I did was email him and with in a couple of days he mailed me back and told me he was sending out the correct piece. I am sure he will do the same for you. Nice color of carpets by the way. Good to know. I emailed him a couple days ago. I've bought a good chunk of stuff from James & Heidi in the past and am overall impressed - kinda why I posted this b/c I thought perhaps I was missing something obvious... I'll be patient and wait for them to respond to my email. (IMG:style_emoticons/default/beerchug.gif) -pt |
ptravnic |
Oct 4 2011, 10:17 PM
Closing the loop on this - I spoke with James and he said that sometime in mid 1972 they changed the style of footwell foam. My smaller foam piece is the early version.
He's going to send me the longer (early style) passenger side version. (IMG:style_emoticons/default/piratenanner.gif) -pt |
gopack |
Oct 5 2011, 06:31 AM
CHEESEHEAD in CA, MARK Group: Members Posts: 744 Joined: 7-August 04 From: Folsom, CA Member No.: 2,472 Region Association: Northern California |
Just curious, does anyone have a side by side pic of the early -vs- late foam piece?
Oct 5 2011, 08:11 AM
no pic, but its quite a bit larger.
Rich |
Lo-Fi Version | Time is now: 10th June 2024 - 08:35 PM |
