FS Brembo 4 piston calipers for vented rotors. Fits rear trailing arms |
bdstone914 |
Sep 29 2011, 11:00 PM
bdstone914 Group: Members Posts: 4,524 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I have a pair of 4 piston Brembo calipers from a 944 that have been machined to fit standard rear trailing arms and 911 vented rotors.
Requires conversion to 5 lug hubs. The calipers have had the ears machined off then drilled and tapped to use a block adapter to bolt to the trailing arm. Asking $275 a set that includes two calipers, two block adapters and grade 12.8 bolts. Shipping is $10. Does not include rotors. No emergency brake provision comes with the calipers. It is possible to use 911 e brake setup with these calipers. |
Lo-Fi Version | Time is now: 22nd May 2024 - 05:30 PM |
