I have a pair of 4 piston Brembo calipers from a 944 that have been machined to fit standard rear trailing arms and 911 vented rotors.
Requires conversion to 5 lug hubs.
The calipers have had the ears machined off then drilled and tapped to use a block adapter to bolt to the trailing arm.
Asking $275 a set that includes two calipers, two block adapters and grade 12.8 bolts. Shipping is $10.Click to view attachment
Does not include rotors. No emergency brake provision comes with the calipers. It is possible to use 911 e brake setup with these calipers.
Click to view attachmentClick to view attachment
