Engine lid hinge bracket, How to reinstall? |
watsonrx13 |
Jul 21 2004, 05:38 PM
Advanced Member Group: Members Posts: 2,734 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
I have an engine lid hinge bracket that I need to remove and weld a new one on. If I have the rear window still in the car, how do I hold the bracket in place to weld it? I do have the engine out of the car, should I bolt the engine lid to the existing one and the new one, then have someone hold the engine lid in place while I weld?
If you have any pics I would appreciate them. |
Jul 21 2004, 06:01 PM
QUOTE(watsonrx13 @ Jul 21 2004, 04:38 PM) then have someone hold the engine lid in place while I weld? if you still have the old one you can trace it out before removal, then just hold it in place with one hand and tack it on, then finish the welding. if the old one is long gone, put the bracket on the lid, hold the lid until it lines up and mark the top and left/right of the bracket, then proceed with the above ^^^ ... Andy |
RustyWa |
Jul 22 2004, 01:17 PM
Working Member Group: Members Posts: 610 Joined: 2-January 03 From: Kent, WA Member No.: 72 |
I removed the rear window to do mine. It took like 5 minutes to remove the window since the butyl tape was only like a year old. Once removed, I used a deep 2" c-clamp to hold the new bracket very tight against the firewall. Tack it in place then remove clamp and attach the lid to check the fit. If it's good, clamp it tight again and finish the welding.
lapuwali |
Jul 22 2004, 02:27 PM
You could also use one of the magnetic "clamps" to hold it on w/o removing the rear window first.
watsonrx13 |
Jul 22 2004, 04:43 PM
Thanks guys for the advise. Now, if I can only find that hinge I bought from PP 18 months ago I'll install this weekend.
Lo-Fi Version | Time is now: 20th May 2024 - 04:39 PM |
