FI computer , how can you tell |
freezing14 |
Jul 22 2004, 07:16 AM
freezing14 Group: Members Posts: 435 Joined: 21-June 04 From: brockville , Ontario, Canada Member No.: 2,233 |
Hi guys, i am getting ready to do a test start of the engine on the ground and as I went throught the stuff that came with the car ( like one and a half car in pieces) I got the car mostly dissaembled and I have 2 computer, 2 wiring harness 2 -3 mps and a load of duplicate stuff that i do not know what they are used for????, the computer box they both look different , the boxes are different ( 1 has a knob on the outside the other one doesnt) the board inside are different too ??? (IMG:style_emoticons/default/headbang.gif) I need to know which one is for a 72 1.7 d-jet
thanks |
tdgray |
Jul 22 2004, 07:50 AM
Thank God Nemo is not here to see this Group: Members Posts: 9,705 Joined: 5-August 03 From: Akron, OH Member No.: 984 Region Association: None |
I know my 73 has the knob. Other than that sorry can't help (IMG:style_emoticons/default/sad.gif)
If you find out that neither works let me know. I have an extra that is in good working order. |
Bleyseng |
Jul 22 2004, 08:06 AM
Giving us the numbers on the boxes would help......
The early FI ECU had no idle knob The MPS's had all kinds of numbers for different years. The 73 1.7 MPS is a 049. Test the MPS's with a vacuum pump by pumping it to 15hg of vacuum and let it sit for 5 min. Good ones hold the vacuum, bad ones leak down. Also use the one that doesn't have the end drilled out, as someone has monkeyed with it. (IMG:style_emoticons/default/monkeydance.gif) Geoff |
freezing14 |
Jul 22 2004, 09:01 AM
I will go trought tonight and get the numbers of the parts and post them back
thanks |
wilchek |
Jul 22 2004, 03:05 PM
Senior Member Group: Members Posts: 506 Joined: 8-June 04 From: Eastern Pennsylvania Member No.: 2,177 |
Check out this web site. Almost too much info, but very helpful with all part #
http://members.rennlist.com/pbanders/DJetParts.htm |
Lo-Fi Version | Time is now: 20th May 2024 - 04:26 PM |
