Wiring A Fuel Pump - Valy please take a look at this, With a Relay in the Circuit |
kconway |
Oct 5 2011, 07:18 PM
Senior Member Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
I'm installing a fuel pump and want to wire it from the fuse board under the dash. I'm going to isolate the pump with a relay so the pump only runs with the key in the "on" postion. I believe I need switched and unswitched power to the relay. Can anyone tell me what terminals and/or fuses on my 74 fuse block would work? I don't have a battery to test for switched power or I would do so.
If I'm off base in my thinking, please let me know. (IMG:style_emoticons/default/blink.gif) Kev |
swl |
Oct 5 2011, 07:50 PM
Senior Member Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
There was a thread not long ago that discussed a way of using the oil pressure sensor and relays to ensure the pump shut off if the motor failed (crash scenario).
Let me look... There it is - http://www.914world.com/bbs2/index.php?showtopic=143464 This approach was done in the engine bay but Valy's cct could be located anywhere. |
SLITS |
Oct 5 2011, 07:55 PM
Mr Gasket (Mallory) made an oil pressure switch. I don't remember how it was wired.
76-914 |
Oct 5 2011, 08:43 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,501 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
(IMG:style_emoticons/default/agree.gif) Autolite, too. IIRC 10-30lb & 30-60 ranges were available + others.
kconway |
Oct 5 2011, 10:22 PM
Can I just jumper a wire from my oil pressure sender connection on my pressure gauge in the dash to terminal 86 of my relay?
Kev |
Valy |
Oct 6 2011, 12:19 AM
Senior Member Group: Members Posts: 1,675 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Can I just jumper a wire from my oil pressure sender connection on my pressure gauge in the dash to terminal 86 of my relay? Kev Yes, its the same wire. The yellow wire comes from the ignition switch. I don't like cutting wires, especially high current ones so I suggest you connect to it under the passenger seat at the seat-belt relay. For the switched power you can use the read/white that feeds the wipers and blower motor in the front or any of the full red wires that feed one of the red fuses (8,10 or 12). And please add a fuse inline with the wire that goes to the fuel pump. Have fun! |
SLITS |
Oct 6 2011, 07:01 AM
I do remember that there are three connections on the switch. One was power to the pump. Of the other two, one was normally closed and it may have come from the starter solenoid wire for startup and the other was normally open where power would come from a switched source when the switch proofed and closed with oil pressure.
I think the oil pressure sender is a variable rheostat/thermocouple (grounding) and I don't think you can tie a line into it to power the pump. |
jaxdream |
Oct 6 2011, 09:42 AM
Senior Member Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
No experience with the idle oil pressure of a -6 , but the -4 has a low idle pressure ( varys from engine to engine )when warm , especially stock unmodified engines . Chosing a switch that will cut off the fuel pump should be concidered with this in mind. Just a thought fellas...
Jack |
Valy |
Oct 6 2011, 10:35 AM
The original fuel pump runs off the relay board not the switch. It is controlled by the FI brain and always switched-off when the engine stops. It's G6, the rightmost element in the diagram with the black/red wire.
The oil pressure switch is F1, in the middle of the diagram, green/red wire, grounded at point 70. As the name says, it's a switch not a rheostat. Further up, K3 is the low oil pressure light. |
andys |
Oct 6 2011, 10:40 AM
There was a thread not long ago that discussed a way of using the oil pressure sensor and relays to ensure the pump shut off if the motor failed (crash scenario). Let me look... There it is - http://www.914world.com/bbs2/index.php?showtopic=143464 This approach was done in the engine bay but Valy's cct could be located anywhere. Though I can see the benefit of an oil pressure energized fuel pump relay, the "crash senario" doesn't mean the motor stops running (to shut down the fuel pump). With that concern (on my EFI V8 car with 58psi), I'm adding in a Ford inertia switch which shuts down the fuel pump relay from an impact or roll-over. One nice feature it has, is a normally open contact that you can wire to illuminate a light to warn you when the switch has been tripped (should someone bump your car while in a parking lot). Find a solid chassis mounting for it, and splice it into the fuel pump signal wire and you're done. The Ford inertia switch is available from Summit, as is the pigtail connector. Andys |
SLITS |
Oct 6 2011, 05:41 PM
The original fuel pump runs off the relay board not the switch. It is controlled by the FI brain and always switched-off when the engine stops. It's G6, the rightmost element in the diagram with the black/red wire. The oil pressure switch is F1, in the middle of the diagram, green/red wire, grounded at point 70. As the name says, it's a switch not a rheostat. Further up, K3 is the low oil pressure light. Kevin is running a 2.4L /6 engine. While there is a possibility of using the idiot lite sender, his oil pressure sender will not function in the mode he is speaking of. |
Mike Bellis |
Oct 6 2011, 06:18 PM
Prospectfarms |
Oct 7 2011, 12:59 AM
Member Group: Members Posts: 495 Joined: 7-March 11 From: Louisville, KY Member No.: 12,801 Region Association: Upper MidWest |
That's useful. Thanks a lot! |
jaxdream |
Oct 7 2011, 09:10 AM
That's useful. Thanks a lot! Yep , thanks , although I'm about as electical as a kitchen match... Jack |
Lo-Fi Version | Time is now: 15th May 2024 - 01:59 PM |
