> Pic's of 8" rims with 225's under "stock" fende
Mueller
post Jan 14 2003, 12:41 PM
914 Freak!
I did some test fitting with an extra set of late model 911 rims i had sitting around in the garage on my last car before the sawzall took care of it....
These have a 52mm offset.
For the rear, the tire hit the trailing arm and the
inside of the fenderwell/trunk wall.
If the trailing arm was notched (about .5") and the fender
well/trunk area was moved towards the car centerline,
I think these would fit just fine. This approach would
be similar to how the hotrod guys "tub" a car to put
big fat tire on it without flares.
(IMG:http://members.rennlist.com/mueller/D90%20view%20from%20rear.JPG)
(IMG:http://members.rennlist.com/mueller/D90%20hitting%20control%20arm.JPG)
(IMG:http://members.rennlist.com/mueller/D90%20on%20back%20of%20914.JPG)
(IMG:http://members.rennlist.com/mueller/D90%20tight%20fit.JPG)
Mueller
- Lo-Fi Version Time is now: 12th May 2025 - 08:55 PM
