Pic's of 8" rims with 225's under "stock" fende |
Mueller |
Jan 14 2003, 12:41 PM
I did some test fitting with an extra set of late model 911 rims i had sitting around in the garage on my last car before the sawzall took care of it....
These have a 52mm offset. For the rear, the tire hit the trailing arm and the inside of the fenderwell/trunk wall. If the trailing arm was notched (about .5") and the fender well/trunk area was moved towards the car centerline, I think these would fit just fine. This approach would be similar to how the hotrod guys "tub" a car to put big fat tire on it without flares. (IMG:http://members.rennlist.com/mueller/D90%20view%20from%20rear.JPG) (IMG:http://members.rennlist.com/mueller/D90%20hitting%20control%20arm.JPG) (IMG:http://members.rennlist.com/mueller/D90%20on%20back%20of%20914.JPG) (IMG:http://members.rennlist.com/mueller/D90%20tight%20fit.JPG) Mueller |
Chris H. |
Jan 14 2003, 02:58 PM
Senior Member Group: Members Posts: 4,030 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Doh! Too Funny! (IMG:style_emoticons/default/biggrin.gif) I was curious to see how those rims looked on the car, never seen them on a 914. I can see that's not an option.
Chris H. |
Lo-Fi Version | Time is now: 18th May 2024 - 03:02 AM |
