Pic's of 8" rims with 225's under "stock" fende |
Mueller |
Jan 14 2003, 12:41 PM
I did some test fitting with an extra set of late model 911 rims i had sitting around in the garage on my last car before the sawzall took care of it....
These have a 52mm offset. For the rear, the tire hit the trailing arm and the inside of the fenderwell/trunk wall. If the trailing arm was notched (about .5") and the fender well/trunk area was moved towards the car centerline, I think these would fit just fine. This approach would be similar to how the hotrod guys "tub" a car to put big fat tire on it without flares. (IMG:http://members.rennlist.com/mueller/D90%20view%20from%20rear.JPG) (IMG:http://members.rennlist.com/mueller/D90%20hitting%20control%20arm.JPG) (IMG:http://members.rennlist.com/mueller/D90%20on%20back%20of%20914.JPG) (IMG:http://members.rennlist.com/mueller/D90%20tight%20fit.JPG) Mueller |
Dave_Darling |
Jan 14 2003, 05:32 PM
914 Idiot Group: Members Posts: 14,986 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Yup, that's the right-front corner of it allright!
That one they cut up without the rest of us. I stopped by after work to help (it was a weekday), but the car was already in pieces. Oh well... --DD |
Lo-Fi Version | Time is now: 16th May 2024 - 09:00 PM |
