Pic's of 8" rims with 225's under "stock" fende |
Mueller |
Jan 14 2003, 12:41 PM
I did some test fitting with an extra set of late model 911 rims i had sitting around in the garage on my last car before the sawzall took care of it....
These have a 52mm offset. For the rear, the tire hit the trailing arm and the inside of the fenderwell/trunk wall. If the trailing arm was notched (about .5") and the fender well/trunk area was moved towards the car centerline, I think these would fit just fine. This approach would be similar to how the hotrod guys "tub" a car to put big fat tire on it without flares. (IMG:http://members.rennlist.com/mueller/D90%20view%20from%20rear.JPG) (IMG:http://members.rennlist.com/mueller/D90%20hitting%20control%20arm.JPG) (IMG:http://members.rennlist.com/mueller/D90%20on%20back%20of%20914.JPG) (IMG:http://members.rennlist.com/mueller/D90%20tight%20fit.JPG) Mueller |
Bleyseng |
Jan 15 2003, 11:30 AM
Aircooled Baby! Group: Members Posts: 13,034 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
I like the pic of the rust free front trunk floor.
Jeroen, I just installed that piece and it wasn't "too" bad to put in. (just a few burns from laying on my back welding) L8Apex, I looked at your update pics. Looks like you have some work to do in the engine bay. How much rust in the engine shelf?? Geoff |
Lo-Fi Version | Time is now: 17th May 2024 - 06:29 AM |
