Rear veiw mirror, BMW retro fit |
72914S |
Jul 24 2004, 06:39 PM
love this shot Group: Members Posts: 1,290 Joined: 10-July 03 From: Pensacola,Fl. Member No.: 900 Region Association: South East States |
Thanks for the idea! (IMG:style_emoticons/default/pray.gif) Here are a couple of pix`s of the fit and finish. Only had to turn the viser pins (pointed end into the mirror).Having trouble with the pictures.I will try later if anyone is interested.
736conver |
Jul 24 2004, 06:50 PM
Advanced Member Group: Members Posts: 2,117 Joined: 25-May 03 From: SE Wisconsin Member No.: 736 Region Association: None |
72914S |
Jul 24 2004, 08:10 PM
pictures
72914S |
Jul 24 2004, 08:12 PM
ruffed out
72914S |
Jul 24 2004, 09:00 PM
Oh, (IMG:style_emoticons/default/jester.gif) by the way I now have a couple of nice stock mirrors for sale .
kc4ixi |
Jul 24 2004, 09:07 PM
Newbie Group: Members Posts: 18 Joined: 29-June 04 From: Jonesborough, TN Member No.: 2,276 |
Looks Great! (IMG:style_emoticons/default/smilie_pokal.gif)
What model of BMW mirror did you use? Was the holes for the pins the only modification you had to do? Robert |
72914S |
Jul 24 2004, 09:27 PM
It was a mid 80`s .Had a square base with a spring and two pins under the base,had to remove that.(dremel with cutting wheel) Used viser holder as a template and drilled the two mounting holes and counter sunk.Also had to round the corners on the base.Then drilled the holes for the viser pins. painted the aluminium with satin black. Done in about two hours including drying time.
kc4ixi |
Jul 24 2004, 09:40 PM
That awesome, I'll have to check into doing something like that.
Thanks for the information! |
Lo-Fi Version | Time is now: 12th May 2024 - 04:10 AM |
